Old 01-28-2008, 10:56 PM   #1
peeling, blistered walls
Drywalled room and ceiling with gloss paint then either a primer or really flat white paint. topcoat looks blistered and peeling in patches, EVERYWHERE.
Using a scraper doesn't get under the peeling and doesn't chip it off. Sanding, with a belt sander and 60 grit has is sot of working but doesn't take off the top coat very well. still peels where the white topcoat is left. the belt sander is not consistant in removal, sometimes going thru even the paper of the druwall.
Any ideas on a quick removal?
chrisj is offline   Reply With Quote
Old 01-29-2008, 09:17 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
No quick and easy solution here, sorry
Scrape and sand
slickshift is offline   Reply With Quote
Old 01-30-2008, 01:18 PM   #3
Painting contractor
Scrape and sand
Ditto and LOL. I pity you - been there, done that.
Thepaintman is offline   Reply With Quote
Old 07-01-2008, 03:37 PM   #4
Done a bathroom, hallway and a different bedroom durring this stripping process.
BUT,,,I found a messy but much easier method.
1) using my power planer I trim doors with I set the blade just under the paint depth (it does bite into or thru the top layer of drywall mud skim coat,and sometimes the plaster under that, and leaves some scraping of the low spots)
2) scrape only the low spots left (going into the skim coat)
3) mixed 1 gal of DAP STUCCO repair into a 5 gal bucket of drywall top coat
and skim coated
4) Anything thick cracks but easy to recoat that.
5) Looks and feels like a lath and plaster wall.
Old 07-01-2008, 09:58 PM   #5
slickshift's Avatar
Sounds like you made an Interior Paint Eater
The concept you came up with is sort of like a tool that is sometimes used on exteriors
Thanks for the update and I'm glad you worked something out
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
Retexturing / Priming walls... scheenstra Painting 3 01-28-2008 08:29 PM
Lead on/in the walls diylady Painting 4 12-09-2007 11:19 PM
help! my walls are troubled donnamarie General Discussion 5 08-29-2007 01:08 PM
