Peeled Off Sheetrock Paper - HELP!! - Painting - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 11:15 AM   #1
Peeled off Sheetrock Paper - HELP!!
Oh boy! I'm having anxiety over a project I started yesterday and need some serious help/advice!
After peeling away stubborn pink wallpaper (which had been painted over), I was left with smooth white surface, in some areas, and brown paper in others. I assumed the brown paper was simply backing left from the wallpaper and noticed that I was easily able to "rub" this off... So I did. I then turned to trusty old Google and realized that the brown paper may have been sheetrock paper, something that I believe is supposed to remain on the wall.
I'm looking to paint the wall, so what should my next action be? Do I attempt to "repair" the wall, even though it just looks white, like the paper wasn't supposed to be there or simply prime and paint? This room isn't anywhere near moisture (i.e. - a bathroom), so is the sheetrock paper super important? Thanks for your help! I can't wait until I can sleep again at night. HA!
HomeHell is offline   Reply With Quote
Old 02-21-2012, 11:32 AM   #2
self help
Prime area where the paper was taken off with a product called GARDZ. A light sanding to smooth down any paper helps. Then, skim it smooth with drywall mud then prime entire area and then paint.
bigjon is offline   Reply With Quote
Old 02-21-2012, 01:34 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Bigjon's got it. Gardz is the primer you want- will soak in and stabilize that mess. Then skim smooth with joint compound ( use a big blade- 12"+ 6"- do a search here on skimming for more info.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-21-2012, 03:07 PM   #4
Gymschu's Avatar
Rewards Points: 460
Brushjockey, I would rip it all out and put in new drywall..........ok, ok, just kidding.
Gymschu is online now   Reply With Quote
Old 02-21-2012, 04:58 PM   #5
BraniksPainting's Avatar
I third this process that bigjon & brushjockey mentioned.
BraniksPainting is offline   Reply With Quote
Old 02-21-2012, 05:23 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Old 02-21-2012, 05:30 PM   #7
ltd
Rewards Points: 536
that was good
ltd is offline   Reply With Quote
Old 02-21-2012, 06:11 PM   #8
Nice Joecaption impression
The Following User Says Thank You to jsheridan For This Useful Post:
Gymschu (02-21-2012)
Old 02-21-2012, 06:14 PM   #9
Are we sure she's not talking about the paper backing? HH, is this "brown paper" below the surface of the wall plane? Is it a hole or gouge? If it's the paper backing are we are advising her to lock down with Gardz, we're going to add significantly to her spackling work.
Tags
drywall , paint , sheetrock , sheetrock paper , wallpaper removal
removing wall paper unprimed sheetrock BruceRY Painting 9 02-08-2012 05:07 AM
fixing torn sheetrock paper cvcman Painting 23 03-29-2011 10:49 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 04:57 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
