Old 10-18-2010, 07:11 AM   #1
peeled ceiling paint off, how to fix?
i sprayed a popcorn ceiling in my master bedroom, and i wanted the edge of the ceiling to be flat, so i taped off the ceiling about 3 inches in all around the room, then sprayed the ceiling and peeled the tape off. the ceiling paint came right off in a majority of spots.
i am fully aware that there are several reasons why this may have happened, but i'm not sure how to get this flat edge around the ceiling any other way.
for now, i really just want to know what the possible ways to fix this would be? do i have to fill and sand the areas where the paint peeled off? if so, what filler is appropriate to use as a filler?
the original ceiling had popcorn about 30 years old, which i scraped down, then primed with one coat of kilz general purpose, then used one coat of a flat latex ceiling paint, i believe it was valspar, the purple coloured stuff.
thanks.
philosophical is offline   Reply With Quote
Old 10-18-2010, 09:14 PM   #2
Matthewt1970's Avatar
is it pulling the paint off the primer or pulling both off the drywall?
Old 10-19-2010, 09:26 AM   #3
That's a good question. I would have to take a closer look, I'm going to say the primer is still there but I can't be sure. Ill take a look tonight
Old 10-19-2010, 05:28 PM   #4
dubinpainting's Avatar
Run your fingure over the peeled spot if it's not smooth or level with the ceiling then fill it with spakle, or joint compound. Sand it smooth until its level with the ceiling this may require several coats. Then prime w/ kills oil primer adheres better, but if u already where using latex just stick with that. Tape wall off then paint. www.dndpainters.com or call a professional!
dubinpainting is offline   Reply With Quote
Tags
ceiling, fix, peeling, popcorn
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General Discussion 4 04-10-2010 08:38 AM
Is ceiling paint special? SR996 Painting 2 03-27-2009 05:51 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
