Peel Stop - Painting - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 09:16 PM   #1
Peel stop
I need to repaint my windows. Someone told me to use peel stop before i paint. They say it glues down the edges of the old paint. Has anyone ever used this?
richiemoe is offline   Reply With Quote
Old 03-27-2010, 06:51 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yes I sell a fair bit of it. You have to understand that it won't work miracles though. You still need to remove as much loose material as possible. Zinsser Peel Stop or XIM Peel Bond will get under the edges of what is left and glue it down.
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
richiemoe (03-28-2010)
Old 03-27-2010, 11:43 PM   #3
is it worth the extra step?
Old 03-28-2010, 12:42 PM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If you are uncertain whether the surface is sound then yes either strip it completely or use a product like Peel Stop to help prevent future peeling. XIM makes another one just for windows and similar areas called Trim Magic, but it's ungodly expensive.
Old 03-28-2010, 06:27 PM   #5
thanks for the info..........
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 03:13 PM
orange peel when painting cabinets ponch37300 Painting 8 04-16-2009 11:55 AM
Hinge Pin Door Stop exterior dws General DIY Discussions 5 02-17-2009 10:58 AM
Peel and stick matching melkisadek Flooring 6 01-16-2008 08:52 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
