Pealing Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 07:51 AM   #1
pealing paint
I painted ny bathroom (which has no vent) several yeara ago and I evidently used the wrong paint. I now have huge areas on wall and ceiling where the paint has pealed. I tried to scrape the areas that were not affected but it won't budge and I made dents in the drywall. How can I get this off, and if I can't what do I do next.
gerryg48 is offline   Reply With Quote
Old 10-20-2008, 11:53 PM   #2
Hi,
That happened to me so I ended up sanding the walls and ceilings until they were smooth. I sort of feathered the rough edges. I followed up with a bleach wash to ensure any mildew that may have been hiding was eliminated. I then went to an established, reputable paint store and had the professional at the store mix mildew deterrent in with the paints. The paint professional suggested I use a semi-gloss for the bathroom walls so I did. For the ceiling, I used a ceiling paint (flat) that was especially for bathrooms where moisture is present. I have had no problem and it has been over 2 years. The sanding really made a difference, but remember to wear eye and respiratory protection, the dust is awful, but the effort will be worth it in the end.
Good luck,
DorothyOlive
dorothyolive is offline   Reply With Quote
Old 10-21-2008, 09:06 AM   #3
Rewards Points: 506
For the spots where the paint is firmly adhering, even after attacking with a scraper, you can just feather the edges with sandpaper and leave it alone.
If this is a bathroom with showers, hairspray, etc., wash down the walls with TSP and rinse. (Try not to use this bathroom for showers or baths a week before and after painting, if possible.)
Next, prime with a Latex bonding primer or an oil-base primer and then topcoat with the bathroom paint of your choice. (Zinsser PermaWhite or Sherwin K&B paint are good choices.)
Is there any way to retrofit a fan into this bathroom?
SirWired
sirwired is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
