Patio Door Staining - Painting - DIY Chatroom Home Improvement Forum
Old 05-12-2013, 05:14 PM   #1
Patio Door Staining
Can you stain the interior side of a vinyl sliding patio door? And does it wear well?
rlbullard is offline   Reply With Quote
Old 05-12-2013, 05:18 PM   #2
Too Short? Cut it Again!
There is no grain as with wood so you cannot stain it literally.
You might experiment with a gel stain.
Or you could try a high bond primer or plastic primer followed by a fi fi foo foo faux faux paint and glaze technique with a wood graining tool.
Could use a wood grain adhesive vinyl tape or other applique I suppose.
Hard to say how well it would hold up. Would depend on how prone it is to being nicked by shoes or its exposure to temperature extremes and uv exposure.
Make sure you prep it carefully whatever you try.
Old 05-13-2013, 01:41 PM   #3
Mr. Paint's Avatar
Faux finishing will be the system that will work. To get a professional tromp l'oeil (sp?) wood grain look, hire a professional. Wood-graining is an art not easily mastered.
Don't be the victim who tells his guest, "I did this myself!"
The guest replies, "I kinda guessed that..."
The Painter's Paint Store where QUALITY is ECONOMY
Mr. Paint is offline   Reply With Quote
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 06:20 AM
Building a new patio cover without footers MStarr Building & Construction 8 01-31-2013 10:06 AM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 08:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 10:53 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
