Patchy Walls - Painting - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 07:10 AM   #1
patchy walls
hey all
this is my first time on the forum, look forward to meeting u all.
my problem is this, being that i am disabled and cant do a great deal my neighbour offered to help me decorate my living room. the wall that i have done is fine but the walls that she has done has lines down it where she has moved the roller over too far and missed about a half inch of wall all across the wall.
now can i just touch them up or will i need to do the entire wall again?
thanks in advance x
danaharrison is offline   Reply With Quote
Old 02-13-2012, 08:09 AM   #2
Gymschu's Avatar
Rewards Points: 502
Touching it up will just make that area stand out like it does now. Best to sand down the wall a bit to remove any high spots & repaint.
Old 02-13-2012, 08:23 AM   #3
thanks for ur reply. i will crack on with it now x
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
