Patchy Paint Finish - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 01:19 PM   #1
Patchy Paint finish
Recently been painting with Dulux trade vinyl emulsion, one wall has dried with a really patchy finish, looks okay from face on, but patchy as u look down the length of the wall, and the light catches. Used nine inch roller and 3 coats up to now. What am I doing wrong and how can I rectify? Thinking of Sanding down to take the sheen off, then recoat as necccasary. Help !
DickyD is offline   Reply With Quote
Old 07-17-2012, 02:39 PM   #2
An old Tradesmen
Rewards Points: 7,816
Moved to painting forum.
Old 07-17-2012, 03:54 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
was it properly prepped first?
Old 07-17-2012, 09:06 PM   #4
ltd
Rewards Points: 536
what sheen did you use? cant say for sure with out seeing but any kind of sheen in paint will show imperfections in wall .try a washable flat paint and i think you will be happy
ltd is offline   Reply With Quote
Old 07-17-2012, 09:22 PM   #5
Too Short? Cut it Again!
Greater the sheen the more differences or imperfections will show. Also remember higher sheen acrylic paints take 30 days to cure to their final surface.
Old 07-20-2012, 06:26 AM   #6
Thanks for the replys, but how do I rectify ? Should i just keep applying more coats, or sand it down and re-apply, or do I need to put a primer on it, or should I change the paint type and use a flat matt on this wall ?
Old 07-20-2012, 05:39 PM   #7
Phil - "the Paint Guy"
Simply rub your hand over the dull area on your wall and compare that to an area that is shiny. Do you feel a difference in texture? Is this consistent on all the spots on the wall? The it's time to re texture, re prime and repaint.
If there is not a difference in texture or how it feels then prep surface prime with a high quality latex primer and re paint...
Good luck...
Cpcphil is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
I use a roller but I get a patchy rough finish maxhammer Painting 10 12-05-2011 04:51 PM
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-09-2011 11:45 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 06:11 PM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
