Patching Holes In Walls - Painting - DIY Chatroom Home Improvement Forum
Old 07-10-2013, 10:59 AM   #1
Rewards Points: 45
Patching Holes in Walls
Whats the best product for patching holes in walls prior to painting??
I know regular old "spackle" will work for little nail holes but if I have larger divots and gouges in the walls - couldn't I just use dry wall coumpound - like what you would use for taping sheet rock??
Thanks!
Dan
dschribs is offline   Reply With Quote
Old 07-10-2013, 12:39 PM   #2
Rewards Points: 13,750
Depends on what you mean by "holes".
Some may need tape, to big and the rock may need to be cut out and patched.
Old 07-10-2013, 01:05 PM   #3
Rewards Points: 45
Nothing too big that will need actual drywall patching. I think the prior owner removed wallpaper and there are just tons of gouges and divots in the wall that they just painted over. Looks like most of the damage was done with something like a metal putty knife.
Old 07-10-2013, 01:25 PM   #4
Jmayspaint's Avatar
Rewards Points: 534
The newer spackle is a lot better than the old lightweight stuff for filling small-medium holes.
Dap makes some, I think its called crack shot?
3M has some new stuff out too.
Its a lot denser than regular spackle, sands easily and won't flash through paint as bad.
But yea, you can just use Sheetrock mud.
Jmayspaint is offline   Reply With Quote
Old 07-10-2013, 07:57 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
If there is any residue wallpaper paste on the walls- it would be a VERY good idea to put a coat of Gardz over it before patching. It will seal down that paste which has a nasty habit of making problems later.
Then a premixed mud like Plus 3 would be fine for patching. Use as wide a blade as you can, sand with a light. Might take 2 apps for deeper stuff.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-10-2013, 09:03 PM   #6
Painting Contractor CT
Rewards Points: 77
Post
Use drywall compound and make sure you prime the patched spots before you apply paint.
Good Luck!
KD PAINTING is offline   Reply With Quote
Old 07-12-2013, 06:01 PM   #7
Rewards Points: 45
Thanks for the info guys. Project went great...other than some pin holes in the mud but I posted that on another thread. . I used that Crack Shot stuff. Love it.
Old 08-09-2013, 09:43 AM   #8
Rockerga
I hate when the patching compound bleeds though the first coat of paint!!!! I just re-painted an old room the same color and the spackling bled right through. (We are redecorating and moving/replacing hanging accessories)
Is there a spackling that works without this pain? I did the same in my garage with very high quality one coat coverage paint and it did the same thing! I applied a second coat and it vanished "for the most part!"
I am obviously not a professional painter and I actually HATE TO PAINT so I surely do not LIKE having to apply two coats!
Rockerga is offline   Reply With Quote
Old 08-09-2013, 09:52 AM   #9
Jmayspaint's Avatar
Rewards Points: 534
Dap Crack Shot works great for me. It claims on the can not to flash paint, when I put it to the test on new wall board painted with a satin finish, it did not show through one coat of interior satin paint at all.
In the first pic you can see where I patched some gouges in the wall. The second pic is after I sanded the patches and applied one coat of satin paint & primer.
The lighting on this wall is excellent due to a window at the end of it, and I could see no trace of the patches.
Patching Holes in Walls-image-3492475863.jpg   Patching Holes in Walls-image-512262169.jpg
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (08-09-2013), Rockerga (08-09-2013)
Old 08-09-2013, 09:54 AM   #10
Rockerga
THANKS!!!! I am sold, will go to ACE today and get that. The other stuff is IN THE TRASH!!!
Old 08-09-2013, 09:24 PM   #11
ltd
Rewards Points: 536
Why take a chance? For spackle give it a quick spot prime with your finish paint .Then take off switch plates have a drink of pop, now spot prime is dry , roll away .
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Rockerga (08-12-2013)
Old 08-09-2013, 10:49 PM   #12
Jmayspaint's Avatar
Rewards Points: 534
That's probably good advice for flat paints.
Anything with the slightest sheen though, I find that spotting with finish paint shows too often.
Even with matte, it can show a sheen differential on the spots that have an extra coat. Sometimes it doesn't really come out till the paint cures all the way.
If spot priming is necessary, I like primer better.
The no-flash spackle is a pretty cool trick, but really not that drastic of an idea. All they had to do was make the dried spackle similar in porosity to paint. Or, to be self sealing in a sense.
Spackle and other patching compounds tend to flash because they are more porous than the paint film they are put on. Eliminate the porosity somehow... Problem solved.
Idk, that's my guess. I wonder if Rick knows spackle too?
Rockerga (08-12-2013), ToolSeeker (08-10-2013)
Patching vinyl siding to "repair" small holes tomseeley Building & Construction 3 06-05-2011 09:12 AM
patching holes in basement cement block wall jhiner Building & Construction 3 06-02-2010 03:03 PM
Patching Walls to Look Good Red Truck Drywall & Plaster 2 02-24-2010 10:54 PM
Patching holes in asphalt driveway joe3534 Landscaping & Lawn Care 5 11-22-2009 09:16 AM
patching walls Barry J Painting 2 05-05-2009 12:21 PM
