Patched A 3" Hole In Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 04:41 PM   #1
patched a 3" hole in drywall
on a high-gloss bathroom wall.
How to feather the new paint over the patch with the existing shiny coats?
Thanks.
Old 07-10-2012, 04:58 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 390
You are going to have to paint the whole wall to make it look right
Old 07-10-2012, 05:05 PM   #3
easiest thing to do is paint the whole wall that the patch is on. paint with a sheen doesn't touch up to well without showing.
Old 07-10-2012, 05:50 PM   #4
Too Short? Cut it Again!
Don't forget to prime the patch!
The Following User Says Thank You to user1007 For This Useful Post:
Gymschu (07-10-2012)
Old 07-11-2012, 06:37 AM   #5
Thanks, all. . .I should have never taken on this simple patch job.
Old 07-11-2012, 06:49 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
Simple things never are. Fact.
to add to how to- after patching sanding priming- I would also spot prime with finish , then do whole wall. A gloss almost always needs 3 times to go away. And spot with same as surrounding area- roller if rolled, brush if brushed for right texture.
good luck!!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-11-2012, 05:43 PM   #7
chrisn's Avatar
Rewards Points: 390
Yes, what he ^ said for sure.
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Drywall repair? hole in wall next to doorframe Charcoal Drywall & Plaster 2 06-21-2010 06:12 AM
Permanent glue to use for a hole in drywall? VLT General DIY Discussions 11 06-09-2010 02:01 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
