Patch & Paint Holes In Aluminum Siding - Painting - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 12:45 PM   #1
Patch & Paint Holes in Aluminum Siding
How would I go about patching/filling holes in aluminum siding and then painting? I have some holes there from changing out our shutters and would like an idea of how to fill these holes and paint them to match the house. (I painted the aluminum siding last year, so I have the paint) Thanks.
gilbo125 is offline   Reply With Quote
Old 02-24-2011, 01:04 PM   #2
Super Master Painter
Ole34's Avatar
how big are the holes???
Ole34 is offline   Reply With Quote
Old 02-24-2011, 01:06 PM   #3
Love for Construction
<*(((><'s Avatar
If it were me I would sand/file down the ridge left from the screws holding the shutters on and use bondo to fill the holes left over.
-luke-
<*(((>< is offline   Reply With Quote
Old 02-24-2011, 01:18 PM   #4
holes are about 1/4 inch, maybe 3/8 inch. not large at all
Old 02-24-2011, 01:23 PM   #5
Ole34's Avatar
shove something in there then caulk/fill ..............whatever works best for you.............
Old 02-24-2011, 02:24 PM   #6
Just caulk it using paintable Caulk that has a high weather rating. It will seal out moisture. You can tool the caulk by licking your finger and passing over the holes. it will push the caulk in as well as smooth the surface hiding it better than just having a painted blob
Mudman is offline   Reply With Quote
Old 02-24-2011, 02:31 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Caulk will shrink. Take a hammer and lightly dent the area where the hole is so there is a slight valley for the product to fill and bit into. Then use exterior grade spackle or even better would be bondo as was suggested above.
Old 02-24-2011, 02:51 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
This is the way to go....and use bondo.
housepaintingny is offline   Reply With Quote
Old 02-24-2011, 03:01 PM   #9
I meant paintable silicone. It wont shrink or crack in weather. For example: GE silicone II paintable silicone. Is rain ready in 3 hours. Paintable in 30 mins. Is ok for freezing temperatures, shrink proof, crack proof.
This is what I use:
http://www.caulkyourhome.com/GE-sili...e-silicone.php
If you go the caulking route just make sure you don't use acrylic caulk. Only silicone. As pointed out acrylic will shrink and crack.
Old 02-24-2011, 03:10 PM   #10
Ole34's Avatar
shoot spray foam in there then knock it down smooth then paint it???? I mean what the hell they're only 1/4'' holes no need to get all labor intensive on them ................
Old 02-24-2011, 04:51 PM   #11
Rewards Points: 616
In your own words, if you did that I would fire you and keep a days pay. Most painting contractors I know would fire you and keep a days pay. There is a way to do things with pride and then there is half a** things.
Old 02-24-2011, 05:08 PM   #12
You got a point there. Spray foam is nasty stuff to get on the siding of your house and never leaves a paintable surface.
Old 02-24-2011, 06:04 PM   #13
If the hole is toward the sun all year around, it will not last.
StevenH is offline   Reply With Quote
Old 02-24-2011, 07:20 PM   #14
Rewards Points: 616
Bondo will last a long time and it won't take you that long to apply. Be sure to get bondo for metal and not wood. We use bondo a lot for dented metal doors, metal door frames and even siding on occasion
Old 02-24-2011, 08:08 PM   #15
Thanks for all the feedback. I'm thinking Bondo is the way to go.
Aluminum Siding Paint Question cellophane Painting 7 03-23-2010 09:53 AM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 02:08 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
