Old 05-01-2011, 06:07 PM   #1
Paper Illusions for kitchen counter?
I've done quite abit of reading on how a person could inexpensively update the look of their kitchen counters and came across Paper Illusions. They sent me samples and the paper seems thick and sturdy and is gorgeous. On their website they claim people use it on kitchen counters. I know you would prep, paper, then coat it with several layers of poly. Just wondered if anyone has tried this or knows anything about it. Thanks.
annie68164 is offline   Reply With Quote
Old 05-01-2011, 08:50 PM   #2
handpaintedbysteve.com
Hey annie,
Can you post the web site, it would help if we know what you/they know?
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 05-01-2011, 09:35 PM   #3
Here's the main site for the product http://www.wallpaperillusions.com/
I also read alittle about it on some diy decorating blogs (don't remember the sites) Sometimes you'll read about how great something is but realize the "reviews" seem pretty "fake" and you're not sure if it's legit or not. This idea does not have alot of info out there either. My mom actual has paper illusions on her walls and it is beautiful stuff. Just not sure about kitchen counters. Thanks!
Old 05-01-2011, 09:53 PM   #4
sdsester's Avatar
Paper is just not a kitchen counter material. If you try this at least put an epoxy or bar type finish over it and promise to never set a pot or cut anything on it. Bad choice for a home kitchen counter.
sdsester is online now   Reply With Quote
Old 05-01-2011, 09:54 PM   #5
Hey Annie,
I used to work with a interior designer who did that effect to her dining room walls, only with tissue wrapping paper. Very unique, however since it offers a bit of a dimensional look, simply applying a couple coats of poly wouldn't do the trick. There's a finish that can be applied over the paper and better serve your needs. I know one product was called "Build 50". Simply said it is a VERY THICK clear mixture that is troweled on (it's much too thick to brush), the concept is one coat of Build 50 is equal to fifty coats of varnish. Many other companies have similar product under different names. Try looking in the Rockler woodworking site and Woodworker's Supply site to name a few. Now you have something to do tomorrow. Hope this helps.
Best of Luck
Steve
The Following User Says Thank You to spraygunn For This Useful Post:
annie68164 (05-02-2011)
Old 05-02-2011, 03:28 AM   #6
Stuck in the 70's
Blondesense's Avatar
I did something very similar to this on the kitchen counter of our previous home. I explained what I did in this thread.
Ceiling texture ideas?
While it did look pretty good after three years, there were a couple of not-very-noticeable cuts where DH wasn't as careful as he should have been. It's not a permanent solution. If there are just careful adults in your household it may last for a few years. If you have kids who never seem to see those spills, or a DH who doesn't pay attention to where the knife blade ends up I wouldn't even try it.
The Following User Says Thank You to Blondesense For This Useful Post:
Old 05-02-2011, 07:17 AM   #7
Gymschu's Avatar
It's much cheaper to just buy a new countertop, IMO.
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Cutting Counter Top sleepysmurf Carpentry 3 08-14-2010 12:16 AM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 04:57 PM
attaching countertop analogmusicman General Discussion 22 08-10-2008 12:53 PM
contact paper removal scatterbrain Remodeling 2 07-06-2008 08:57 AM
