Paintinted Walls - Painting - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 04:09 PM   #1
Paintinted walls
Just applied two coats of red paint/with primer. Wall does not look professionally painted. Seems ot have llight spots. What can I do?
jharper is offline   Reply With Quote
Old 05-26-2011, 04:44 PM   #2
the Musigician
DangerMouse's Avatar
What brand of paint? Red paint is notorious for needing numerous coats, even with good paint.
More with lesser quality. It will probably need another coat..... or more......
DM
Old 05-26-2011, 04:52 PM   #3
A Little Of Everything
Rewards Points: 1,364
Bold colors are tough to work with. They usually require at least two coats, unless you're painting over a very similar color.
DrHicks is offline   Reply With Quote
Old 05-26-2011, 04:59 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
[quote=jharper;655547]Just applied two coats of red paint/with primer. Wall does not look professionally painted. Seems ot have llight spots. What can I do?[/quote]
One thought comes to mind
Hire a professional painter
I have a couple more if you are interested.
Old 05-26-2011, 05:06 PM   #5
ltd
Rewards Points: 536
with out knowing the color of red or the base it was mixed in i would say you need to use a gray primer . you might say well ill just put another coat on. nope it dont work that way .gray primer like a charcoal gray .oh did i say gray primer yep i did .one coat gray primer 2 top coats and youll be golden .i mean red
ltd is offline   Reply With Quote
Old 05-26-2011, 05:08 PM   #6
the Musigician
"red paint/with primer"
How did I miss that? In my mind, I saw "2 coats of red over primer"....
I guess I know what the problem is now for sure. 2 more coats should do it.... maybe....
DM
Old 05-26-2011, 08:11 PM   #7
Buy Ben Moore Aura, the only paint I've ever seen red cover in two coats, over white walls.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
