Painting Woodwork - Painting - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 11:39 PM   #1
painting woodwork
my house is six years old, I won't be moving any time soon. But, I really want white woodwork. Will painting my oak woodwork lessen the value of my home/
LEESWAY is offline   Reply With Quote
Old 09-19-2011, 02:28 AM   #2
Old Hand
Very interesting question and the answer is it depends...upon where you live and the status of "oak" as a decorator item. On the West Coast Oak was used quite a bit in the 70's/80's so if you are on the West Coast, painting the Oak (molding) will not hurt the value of the home as molding in almost all new homes is now painted. In addition, I am a REALTOR who also has been a Carpenter and DIY'er for years. Interestingly enough, my accent wood in my home is all Oak and yes it makes the house look dated. We have considered painting it but I do not like the way that paint lays on hardwoods, it never seems to stay even. As a Realtor, I would tell you to paint if you are ready to sell, if you are planning to stay in the home I would make the choice based upon how the finished product will look; buy a sample of Oak and paint it the color you are considering. If you do decide to paint, make sure you use steel wool (at the minimum) to break the surface; I would recommend a finish sander. If you don't, you are going to be sorry you painted.
iliketowork is offline   Reply With Quote
Old 09-19-2011, 07:25 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
Please read the thread "wood trim" that is down the page a bit- same question.
Also i have to comment on steel wool- don't use it for anything that will be finished with a waterborne paint. Anything left will rust.
As a pro I find almost no use for it- get a sanding sponge- works better and easier.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-19-2011, 09:32 AM   #4
Gymschu's Avatar
Rewards Points: 486
I never like to see oak painted............looks worse than the worn out clear coats that cover the oak.......I say DON'T DO IT!
Old 09-19-2011, 09:42 AM   #5
I think it will be better if you go for some other option.
JohnDsouza is offline   Reply With Quote
Painting Stained woodwork and trim flowergal Painting 2 03-25-2010 11:25 PM
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 08:50 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
painting 1950's woodwork lizluther Painting 2 11-30-2008 10:28 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
