Painting A Woodstove Brick Hearth - Painting - DIY Chatroom Home Improvement Forum
Old 08-29-2009, 10:27 AM   #1
Painting a Woodstove Brick Hearth
I am going to paint a brick hearth backsplash the same color as my walls. What is the best application for this? My plan was to wash the brick with Dirtec. Let dry. Do I need to clean the brick? Caulk any cracks in the grout lines. Prime with a Kilz latex primer ext/int. Then paint with a latex paint two coats-semi gloss interior. Is this correct? What seen would be the best? Should I use a specific latex paint for masonry so it does not yellow from the heat? I will be getting my paint at Home Depot. Hey Thanks!
skiwindjunkie is offline   Reply With Quote
Old 08-30-2009, 07:03 AM   #2
Remodeling Contractor
worse statement was getting paint form Home Depot or Lowes. Both are low end and quality paints are always a better value. Use masonry paint after proper cleaning. Heat has nothing to do with this application of paint type.
Old 08-31-2009, 08:22 AM   #3
that was helpful
Old 09-24-2009, 10:25 AM   #4
Finished
Since I did not get any useful advice I thought I would post my finished product. I did not wash the brick as it was clean. I used a Kilz 2 latex primer. Then I caulked brick gaps & holes as well as the trim with Phenoseal Vinyl Adhesive Caulk. Two coats of Glidden's evermore interior latex eggshell paint. I also painted the woodstove with High Heat Black RustOleum. I did not use the advice from this website but did ask at stores & researched it on the internet with better answers.
Painting a Woodstove Brick Hearth-woodstove-progress.jpg   Painting a Woodstove Brick Hearth-woodstove-after.jpg
Old 09-24-2009, 05:24 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
Please post back after you have had a fire going for a few days.
chrisn is online now   Reply With Quote
Old 09-25-2009, 09:23 AM   #6
Had a fire almost every night since. The stove had a mild smell from the woodstove paint on the first fire but so far it looks and works GREAT!
Old 09-26-2009, 07:59 AM   #7
It looks very nice, good job
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Painting brick advice jmb324 Painting 10 12-09-2010 01:25 PM
Painting Brick RMCarner Painting 17 07-26-2009 03:45 PM
Painting Brick? Eipnvn Painting 3 05-19-2009 10:31 AM
painting a woodstove JAVAMAN Painting 7 05-12-2009 06:47 AM
