Painting Wood Trim - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 12:43 AM   #1
painting wood trim
We have stained trim and I want to paint it white. I would like a smooth finish and would like to know what type of paint to use.
vickinicholls is offline   Reply With Quote
Old 01-14-2012, 03:45 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 474
Lightly sand with 100 grit paper, clean, prime and paint
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (01-14-2012)
Old 01-14-2012, 05:57 AM   #3
Welcome to the forum Vicki. I would give the trim a light sanding with 150 or 180 grit paper. Dust if off well and then use an oil base bonding primer or Zinsser BIN. Chrisn's suggestion of Fresh Start will work as well, just preference. I agree with the finish choice.
Old 01-14-2012, 10:14 AM   #4
the right primer for the wood
Both reply's are good but if your are working with oak be prepared for the grain of the wood to show. If you use Benjamin Moore Fresh Start alkyd enamel underbody white for a primer it will help hide the grain of the wood. the can number is 21700 any bm dealer will know what you are talking about. remember the the surface should always be clean dull and dry and nothing replaces a primer. good luck and always have fun.
shives is offline   Reply With Quote
white trim vs. wood stained nwalford Interior Decorating 17 02-28-2011 02:54 AM
Painting over wood stained trim novaman75 Painting 1 08-13-2010 03:27 AM
Painting over wood stained trim elise77 Painting 7 07-03-2010 11:02 AM
Painting wood finished trim white... leverne99 Painting 12 06-06-2009 06:31 PM
White vinyl windows with wood trim... crazy? rnjsbungalow Interior Decorating 5 04-16-2009 05:53 AM
