Painting Wood Panel - Painting - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 08:51 AM   #1
Question
painting wood panel
I think i messed up big time! I am painting my wood panel, I asked the paint person do i need to sand and he told me no you only have to prime it. So I primed my kitched and bathroom. No i hear your supose to de gloss it. What should I do just paint over it, strip it, sand it? Please someone help!
amanda516 is offline   Reply With Quote
Old 06-05-2009, 09:34 AM   #2
NAV
whats done is done. see how it holds up. I think you will be fine.
NAV is offline   Reply With Quote
Old 06-05-2009, 09:51 AM   #3
Haste Makes Waste
With a similar issue, I was told to use OIL based primer then paint with Latex.
saggdevil is offline   Reply With Quote
Old 06-05-2009, 09:53 AM   #4
NAV
when you paint over paneling the grooves bleed through latex 90% of the time. its a good idea to prime with oil.
Old 06-05-2009, 10:45 AM   #5
so should i paint over the primer or sand the primer off??
Old 06-05-2009, 10:58 AM   #6
Haste Makes Waste
you can go ahead and paint over the primer. If it was latex (water based) and not oil based primer it could possible flake or chip. If you used water based primer, i'd put a coat of oil based primer on it then paint.
Tags
wood panel mess up?
how long to let pressure treated wood dry before painting? vendejp Painting 18 08-08-2012 08:53 PM
painting over a wood stain franko24 Painting 5 10-13-2010 07:52 PM
Wood panel accents warmby Interior Decorating 7 04-10-2009 10:16 AM
Painting wood window casing PatA Painting 1 12-06-2008 03:50 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
