Painting A Wood Door - Painting - DIY Chatroom Home Improvement Forum
Old 04-15-2007, 09:04 PM   #1
Painting a wood door
I want to paint 2 wooden doors, ones a slider and the other is a interior 6 panel door. I know I need to prime it first but what kind of primer should I use? Should I use bonding primer, oil based primer or latex primer? Confused, why so many primers??
diylady is offline   Reply With Quote
Old 04-15-2007, 10:26 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by diylady View Post
... why so many primers??
Because there are so many different things to paint!
Ask any professional painter what the best primer is and they'll ask "What are you priming, and why?"
So...What are you priming?
Is that bare wood? Stained wood? Stained and Poly'd (shiny)? Previously painted?
slickshift is offline   Reply With Quote
Old 04-17-2007, 04:33 PM   #3
The door is stained and I think?? poly"d.
Old 04-17-2007, 07:15 PM   #4
slickshift's Avatar
Hmmm....lightly sand, wipe off the dust, prime with a quality oil-based primer, then two coats quality latex (I'd recommend a waterborne enamel)
If it's real dark stain, or in iffy condition, I'd prime with a pigmented shellac
But that stuff is pretty stinky, and should only be used if needed
Old 04-17-2007, 07:27 PM   #5
Rewards Points: 150
Talking
And don't do like I did and try to prime and paint it without laying the door completely flat.
slick, isn't there a particular type of roller to use on flat surfaces with oil-based primer?
shapeshifter is offline   Reply With Quote
Old 04-18-2007, 07:40 PM   #6
Normally it is recommended to use a 3/16" nap roller to eliminate any stipple in the finish.
Also, don't be afraid to use a waterborne primer. I would recommend a block-out primer to make sure that the stain does not bleed through the primer and finish coat.
Paintguru is offline   Reply With Quote
Old 04-18-2007, 07:56 PM   #7
slickshift's Avatar
I wouldn't use a roller on a 6 panel door
I'd recommend all brush work
Aside from the fact that all rollers leave to much stipple for me (for trim and doors and such, with a six-panel, you'll need to use a brush for the panel edges and bumps no matter what
No sense in wasting the time and money on wetting a roller sleeve for 4 minutes of work, that'll have to be brushed out to not leave stipple anyway
I also wouldn't recommend a water-based primer when painting a stained and/or maybe poly'd door
Old 04-19-2007, 07:00 AM   #8
We sell waterborne block-out primer daily to customers repainting kitchen cabinets and doors. Of course, we are selling a premium $35 dollar a gallon product, we would never recommend a regular wall primer for these kinds of projects.
Old 04-09-2008, 11:10 PM   #9
I am also getting ready to prime some bedroom doors, the oldschool natural wood-like finish you see in home built in the late 70s-early 80s.
I am painting them white... I have lightly sanded them down using a black & Decker detail palm sander and now I'm ready to prime. I will be using a quality brush but wondering if my primer is ok:
Sold at Kent building supplies under the name "Prime Time"
Super latex undercoater 100% acrylic Paint - stain blocking primer
-Undercoater before applying the topcoat
-Prepares and seals the surface
-Super Adherent
-Non-Splattering, easy application
-Minimal Odour
-Prevents wood Tannin stains.
Materials:
Painted or new wood, bare steel, siding, masonry, concrete, wall board, plaster ect...
Surfaces:
Shingle roofing, walls, doors, windows and previosly painted surfaces, ceilings, woodwork, ect...
It says to only apply one coat, does it matter?
earthad1 is offline   Reply With Quote
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 12:24 AM
Hollow wood door with hole where the hing plate goes earlc General DIY Discussions 4 07-08-2007 01:21 PM
Repairing the wood for painting bofusmosby Painting 4 06-16-2007 11:55 PM
Wood Interior On Patio Door with White Moulding tom_patriot Remodeling 3 12-06-2006 05:51 PM
Help with painting an interior door Kim Painting 2 03-05-2005 12:38 AM
