Old 02-03-2013, 01:18 PM   #1
Painting windows and primer is pulling away in spme spots. Help
I am priming windows and the paint is pulling away in areas. Not sure why. I caulked windows and was wondering if it can be that. Also i know i am painting over another laytex paint. How can I get the paint to stick in these areas?
Painting windows and primer is pulling away in spme spots. Help-image-148078127.jpg
mommomdyi212 is offline   Reply With Quote
Old 02-03-2013, 01:42 PM   #2
Gymschu's Avatar
Looks like some sort of silicone based cleaner was used on the woodwork? Either that or someone smeared silicone caulk all over the woodwork and tried to wipe it off. I would recommend a thorough sanding with a palm sander to remove whatever "Gunk" is on the woodwork. Clean thoroughly with warm water only and wipe off with a towel to really get it clean. Then retry applying your primer. You may have to resort to using a bonding primer like Zinsser's 1-2-3........it sticks to anything.
The Following User Says Thank You to Gymschu For This Useful Post:
ltd (02-03-2013)
Old 02-03-2013, 01:47 PM   #3
Thank you so much for your advise. It could be the caulk I used. Dang! I should have done that last after painting.
Old 02-03-2013, 02:55 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Did you use !00% silicone caulk? Read the tube- does it say paintable?
If not- IT ISN"T.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (02-03-2013)
Old 02-03-2013, 04:05 PM   #5
If not- IT ISN"T.
Well you are right. That caulk isn't paintable and the Zinsser123 isn't working either. Any suggestions? Do i need to sand the windows to get the caulk off? This is frustrating
Old 02-03-2013, 04:24 PM   #6
cdaniels's Avatar
I would use a razor blade to cut and scrape the caulk off.You're going to have to get it off before the paint will bond.Caulk it with a paintable caulk before priming with the 1-2-3.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 02-03-2013, 04:35 PM   #7
A green scotch bright will help get it off.
Old 02-03-2013, 05:34 PM   #8
paper hanger and painter
chrisn's Avatar
not silicon
Old 02-03-2013, 07:31 PM   #9
I find it hard to believe you got that much caulking on that big an area.
I'm thinking it's possible that paint is old, not mixed up enough or it's at one point froze.
One way to find out try it in an area where you know there's no silicone.
Old 02-03-2013, 11:32 PM   #10
thats what i was thinking. gotta be really messy for it to get that bad.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-03-2013, 11:35 PM   #11
You would have to use your whole palm of your hand not just a finger to spread it that wide.
Old 02-03-2013, 11:47 PM   #12
cdaniels's Avatar
Have any of you guys ever seen any DIY'ers caulk? No offense to the OP but I have seen them smear it up really good.
The Following User Says Thank You to cdaniels For This Useful Post:
jsheridan (02-04-2013)
Old 02-04-2013, 12:42 AM   #13
I would try to do as good a job as possible with physical removal and then do a coat with an oil primer. That is what we do and it always seems to stick to the silicon.
Silicon is very good at what it does but its applications are limited. Unless your project involves tiling, counters, a shower, or a bathtub, steer clear of the silicon!
Windows is offline   Reply With Quote
The Following User Says Thank You to Windows For This Useful Post:
Gymschu (02-04-2013)
Old 02-04-2013, 07:40 AM   #14
Gymschu's Avatar
Painters wouldn't do that, but, General Contractors would!
Old 02-04-2013, 06:01 PM   #15
Thanks for your reply. I Put this silicone on 7 windows! What a huge mistake! Its taking me 2 days to scrape it away. Is it okay if i prime first then caulk with the paintable caulk? Or should I caulk first?
New windows and trim painting slowbiker46 Painting 0 08-25-2012 08:34 AM
New windows and siding painting - Help needed slowbiker46 Painting 1 08-22-2012 12:48 PM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 07:52 PM
painting project, large home interior - need planning help bokeh Painting 9 11-06-2010 10:45 AM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 10:06 AM
