Painting Window Frames - Painting - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 08:39 AM   #1
Painting Window frames
I own a property maintenance company and have painted but am not a pro. I am starting a project with about 40 window frames at some condos. Just looking for some specifics on how to go about this. Window frames are pealing on the corners and in some spots. I think I will scrape those, than sand the rest of the frame to get a rough surface to prime over, or should i spend time getting down to wood on the paint that is still looking good? The windows swing open, any tips on painting them without having them stick together in the end?
moeburton is offline   Reply With Quote
Old 11-08-2010, 08:50 AM   #2
Try here for professional questions.
http://www.painttalk.com
mark942 is offline   Reply With Quote
Old 11-08-2010, 04:09 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
This site is for pros only, they will just recommend yopu back here.
Old 11-09-2010, 05:38 AM   #4
chrisn This site is for pros only, they will just recommend yopu back here.
Beings that the OP owns a property maintenance business and re-painting 40 window frames in a condo complex. One can only surmise that this would come under the heading of a commercial/professional question, not a DIY type of Q&A. Glad you posted a answer for the OP chrisn, very informative............
Old 11-09-2010, 11:53 AM   #5
chrisn's Avatar
Rewards Points: 388
It may very well be a valid question but as I stated , this site is for PROFESSIONAL painters and I see you helped a lot also
New window frames? PCMLR Carpentry 2 10-08-2010 11:23 AM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
painting over stained window frames jerome8283 Painting 13 02-22-2010 06:09 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 09:24 AM
