Painting Window Crossheads - Painting - DIY Chatroom Home Improvement Forum
Old 08-17-2014, 06:43 PM   #1
Rewards Points: 12
Painting window crossheads
I need to paint the window crossheads on the outside of my house. Two of them pose a problem. The existing paint is crackled for lack of a better term. Since the cross heads are a foam material, I cannot scrape away the old crackling paint. I need to find some way to smooth it out to repaint it. I also can't really sand it or it will ruin the foam material. Do you think using a spray paint will fill it in enough to eventually get a smooth looking finish with several applications? Or is there something I can brush over the crackling paint to smooth it over before painting? I hope my description makes sense. Thank you.
Sent from my SPH-L710 using diychatroom.com mobile app
slyguysmoke1 is offline   Reply With Quote
Old 08-17-2014, 08:07 PM   #2
Rewards Points: 13,724
Really need a picture.
No form of paint is going to fix cracking.
Old 08-17-2014, 08:32 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
There are specialty primers for that purpose. They don't exactly create a perfectly smooth surface, but can help make a more uniform surface and prevent future cracking.
Here is one example that is widely available.
http://www.rustoleum.com/about-rust-...inding-primer/
Another option is to fill the cracks with caulk. I will sometimes do this with cracking lead paint rather than remove it when removal is not a good option.
Jmayspaint is offline   Reply With Quote
The Following 2 Users Say Thank You to Jmayspaint For This Useful Post:
Gymschu (08-18-2014), slyguysmoke1 (08-17-2014)
Old 08-17-2014, 09:31 PM   #4
Rewards Points: 12
Thanks jmayspaint! That may be just what i need.
Painting Vinyl Clad Window? wombosi Painting 8 08-23-2012 09:36 AM
Painting inside of vinyl window ntbilodeau Windows and Doors 2 08-02-2012 11:33 PM
painting inside window citygirl Painting 6 02-13-2011 01:45 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
