Painting White Enamel Gloss Over Dark Gloss - Painting - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 02:24 AM   #1
Painting white enamel gloss over dark gloss
Hi I am renovating a 70s house and trying to paint white gloss (enamel arcylic) over the existing dark grey gloss. I have buffed it with sand paper but the grey is bleeding through and I have used 4 coats of single coat on one door frame already. It was suggested that I could use 1 part PVA to 10 parts water on the frames and skirting to provide a sealant to stop the colour bleeding through, I am not sure if this will work. I would appreciate any advise that will save me time and money.
Dubh is offline   Reply With Quote
Old 08-31-2012, 02:30 AM   #2
Hi I am renovating a 70s house and am painting white enamel gloss over dark grey and the grey is bleeding through. I have given it a reasonable sand but the I have had to use 4 coats of the single coat gloss to cover the grey. Would a mix of PVA and water painted over the sanded frames and skirting provide a sealant to prevent the bleeding through of the dark colour or is there another better way. I would appreciate any advise that would save me time and money. Thanks
Old 08-31-2012, 03:39 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 602
Stain blocking primer. Pva will not do it
Zinnsers Cover Stain, Bullseye123, etc
The Following User Says Thank You to chrisn For This Useful Post:
user1007 (08-31-2012)
Old 08-31-2012, 05:33 AM   #4
painting white enamel over dark gloss
Thanks Chrisn I'll get it in the morning!
Old 08-31-2012, 06:39 AM   #5
Too Short? Cut it Again!
Yup!
Or a specific alkyd primer/enamel underlay since you probably have an oil finish on there if it is high gloss.
You must still prep and scruff up the surface you are painting though so the primer will adhere.
Old 08-31-2012, 06:43 AM   #6
Rubbin walls since'79
Brushjockey's Avatar
The pva Idea is terrible- forget it.
There is a difference between bleeding and coverage. Bleeding is something literally chemically coming through the paint, and coverage is just that- hiding what is beneath.
Primers in general are good for many things, for you adhesion- sticking to the original surface- is important with the first thing to hit it. But they are not great at coverage. So use a good bonding primer like Zinsser 123 for that first coat- but don't expect it to get rid of the black. You will see all your strokes, just put it on even.
A hi quality paint has more hiding power- and I would expect at minimum that it would need the prime and 2 good coats to have a hope of getting it. As a pro I would not be surprised with 3.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 08-31-2012, 07:17 AM   #7
And as mentioned in other posts by me and others, a white with even a couple drops of black, umber, sienna (old bottle tint names and not current but you get the idea) or whatever will cover better than stark, glaring white white. And frankly, a slightly off white will look better.
I know the Benjamin Moore factory off-whites best and like Atrium White, Super White. They still look like white to the eye. I think they look much better next to wall color.
painting high gloss on white laminate oldhouse49 Painting 9 02-06-2012 08:09 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
Cabinet Painting: Gloss vs. Semi Gloss digexpressions Painting 1 12-29-2007 03:47 PM
Painting a door red outside, white on the inside - quick question joeyboy Painting 6 08-26-2007 03:37 PM
Whatcha thinka NOT painting interior moulding white? Davo Interior Decorating 7 07-07-2007 07:58 PM
