Painting With Waterbourne Enamels - Painting - DIY Chatroom Home Improvement Forum
Old 12-29-2007, 11:12 PM   #1
Question
I read with interest the information on this forum regarding using ProClassic Waterbourne and how it maintains a "wet edge" for only about 30 seconds. I have attempted to repaint our kitchen cabinet doors with BM K&B acrylic satin finish enamel and had all kinds of problems with it (though probably the problems were more with the painter than the paint).
Say I have a flat surface 15" wide by 30" long. If I paint a straight strip with a 2-1/2" brush, I can manage to keep painting into a wet edge to the end. But when I go back to paint the second strip, that long edge is no longer wet.
If I paint across the panel and then go back to the starting edge, I no longer have a wet edges.
How to handle such a project? I have tried rolling with a 4" roller and a foam pad and ended up with a rough finish; I also tried with a fabric roller with low nap and again ended up with a rough surface. So I'm stymied for now.
Any advice would be very much appreciated.
Jim
jimc is offline   Reply With Quote
Old 12-30-2007, 06:05 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
FLOETROL made by Flood
Old 12-30-2007, 08:24 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
K & B is not a particularly difficult paint to work with, I do suspect it was more of a tools or technique issue
The waterborne enamels I've worked with are a little tricker than K & B
I can't say for the open time of Pro Classic, but most quality waterborne enamels need quality premium tools, good technique, and a quick application to look good
Use a good quality premium brush, do not over-brush, work quickly and smoothly, and try some floetrol in your cut pot if needed
(http://www.flood.com/Flood/CustomerS...oetrol+FAQ.htm)
slickshift is offline   Reply With Quote
Old 12-30-2007, 02:36 PM   #4
Pro Painter
Try rolling it on then brush it out. This should help with getting it on quickly and maintaining a wet edge.
Roll it with 1/2 or 3/8 nap, dip the brush as necessary to maintain consistent mil. thickness.
joewho is offline   Reply With Quote
Old 12-30-2007, 09:03 PM   #5
Enamel Painting Techniques
I wouldn't disagree that it is my technique that is at fault. I know I take too much time laying the paint and trying to get everything perfect.
Given the scenario I described in my initial post, how should I paint such a panel - paint working fully across the panel and then on to the next row or should I paint a full lengthwise strip and then return to the second strip? And, as I understand from some other posts, dip my brush about halfway, don't wipe it, apply paint in one long continuous strip and then brush lightly back across the strip I just painted?
JimC
painting a woodstove JAVAMAN Painting 7 05-12-2009 06:47 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
