Painting Walls Help After Removing Wallpaper - Painting - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 02:19 PM   #1
Rewards Points: 121
Painting walls help after removing wallpaper
I have removed all the paper form my LR walls and and getting ready to paint it a flat laytex off white. After I wash the walls do I need to prime ?? If so oil or laytex ??
cvcman is offline   Reply With Quote
Old 03-08-2011, 02:37 PM   #2
DIY staff
Rewards Points: 7,174
Wash---let dry--lightly sand the walls--it's surprising how many little bits of crud will be stuck to the surface. A latex primer is a very good idea.--Mike--
Old 03-08-2011, 02:40 PM   #3
Rewards Points: 121
Like Zinsser 123 ?? I was told to use OIL primer incase there was ANY glue left ...They said using laytex primer would lift the glue and oil wouldnt .....
Old 03-08-2011, 02:56 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
CVC- the best primer for after stripping is Zinsser Gardz. It is a clear bonding and penetrating sealer, and is actually superior to oil for this.
good luck.
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
oh'mike (03-08-2011)
Old 03-08-2011, 02:59 PM   #5
Rewards Points: 121
is that a laytex product ?? So its not white colored ??
Also I have other walls that I stripped before and washed down and painted with laytex paint, they look fine but If I want to repaint I can just go over the flat laytex on these walls right ?? I assume that IF I painted these walls and the paint is fine then it must be stuck and there must not be any glue on the walls right ??
Old 03-08-2011, 03:08 PM   #6
The problem - that's being solved with the gardz - is that glue reside, particularly thick spots, are reactivated later either by the moisture in the paint or even humidity getting through a paint to the glue . It will expand , crack and look bad. Gardz (or oil) will create a vapor barrier that moisture will not penetrate.
Your previous rooms might be ok to repaint, but as stated, as long as nothing is making a barrier to any glue, it could be problems in the future. It's a crap shoot.
Gardz is unpigmented, a waterborne product that is very thin. It will also dry and be ready to recoat in an hour.
It's the stuff. Believe me now or believe me later.
And it's Latex, not laytex.
Old 03-08-2011, 03:11 PM   #7
Rewards Points: 121
the other rooms have been painted a couple years now so they should be fine right ?? They still look good ???
You think the Gardz INSTEAD of a oil based Zinnser white low order primer ??
Old 03-08-2011, 03:12 PM   #8
Rewards Points: 121
Oh, and just a low knap roller ??
Old 03-08-2011, 03:12 PM   #9
yes, and go slow- it is thin.
Old 03-08-2011, 03:14 PM   #10
Rewards Points: 121
you thnk the other rooms are ok ?? Again they have been painted for at least 2 yrs and look good
Old 03-08-2011, 03:19 PM   #11
"Your previous rooms might be ok to repaint, but as stated, as long as nothing is making a barrier to any glue, it could be problems in the future. It's a crap shoot. "
Old 03-08-2011, 03:23 PM   #12
Rewards Points: 121
so even though the other 2 rooms have been painted a couple years and look good if I recoat they MAY bubble up ??? On of them has 2 coats of two different colored paints doen a few years apart and never had a problem. Guess I just dont see how after this many years and coats of paint how one more would be a problem....
Old 03-08-2011, 03:30 PM   #13
Question answered. Twice.
Old 03-08-2011, 03:33 PM   #14
Rewards Points: 121
Humm...So...IF I repaint the other rooms that are painted I still should use Gardz before recoating ???
Also any other product I can use other than Gardz because noone around here has that Zinnser product
Old 03-22-2011, 12:17 PM   #15
Rewards Points: 121
I cant find Gardz anywhere, will an oil based primer work ??
Painting Interior Walls - Touch-up Job buzzer Painting 9 01-11-2012 05:30 AM
prepping walls after wallpaper removal.... diy'er on LI Painting 10 11-09-2010 08:57 AM
Painting Walls Red Wazoe Painting 8 12-07-2009 11:07 PM
Please help! on painting mobile home walls LilDarlin Painting 11 08-17-2009 05:04 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
