Old 09-22-2011, 09:36 PM   #1
Question
Painting walls after wallpaper removed
I have removed wall paper and plan to paint the walls. There is glue left on the walls. Should I remove the glue by sanding or can I just put a primer coat of paint over the glue? I am worried about how the glue will react with the paint.
sys72db is offline   Reply With Quote
Old 09-22-2011, 10:39 PM   #2
ltd
yep the paint will reativate the paste and youl have a mess on your hands . i have seen it many times and it looks like . . . . . so what you can do is wash the paste off .bucket ,spray bottle ,hot warter ,paste remover like dif or another brand ,puddy knife ,6 ingh broad knife,sponge, and most important geen scrub pads . when paste is off prime with zinnzer cover stain oil base this will take care of residiaul paste, then 2 top coats quility latex paint
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
sys72db (09-23-2011)
Old 09-22-2011, 11:19 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
ltd- you give good advice- but please use spel check! Thx!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 09-22-2011, 11:34 PM   #4
Gymschu's Avatar
Brushjockey, he called wallpaper adhesive GLUE! Uh-oh.
Old 09-23-2011, 04:47 AM   #5
paper hanger and painter
chrisn's Avatar
I see not 1 but 4 pastes
I would use Gardz instead of Cover Stain
Old 09-23-2011, 10:32 AM   #6
I'm going through a similar process of removing wallpaper, and I just want to make sure I have the process right:
1) Remove Wallpaper
2) Wash & scrub walls, try and get all that leftover glue and residue off
3) Apply a coat of Gardz
4) Patch, Sand, and Gardz any of the trouble spots
5) Paint!
Is that right or am missing something?
Grundalow is offline   Reply With Quote
Old 09-23-2011, 10:43 AM   #7
You got that right!
Old 09-23-2011, 04:58 PM   #8
ltd
i have never used gardz i'm going to try it one day ,but why i like cover stain is that i can roll it on and it leaves a nice soft stippel.plus its like 22bucks a gal,
Old 09-23-2011, 05:14 PM   #9
chrisn's Avatar
ya, but it's oil and it stinks and Gardz cost about $22 also
The Following User Says Thank You to chrisn For This Useful Post:
ltd (09-23-2011)
Old 09-25-2011, 02:39 PM   #10
pwilson2011's Avatar
I would get everything of the surface before painting - sanding, scraping , whatever it takes. The more time and care you spend on prepping the nicer the finished result - I always say prepping is 90% and the painting is 10%
pwilson2011 is offline   Reply With Quote
Old 09-26-2011, 02:39 PM   #11
retired guy
I have read the posts about removing wall paper, scrubing , etc. and using Gardz primer. My question has to do with a border (near ceiling). That's the only place where there is wall paper, paste, etc. Can I use the Gardz primer at the border area only? Will there be a noticeable line where it stops? What's the best way to achieve a good job?
igneous is offline   Reply With Quote
Old 09-26-2011, 05:21 PM   #12
chrisn's Avatar
Are you painting the walls?
Old 09-26-2011, 06:14 PM   #13
retired guy
In response to chrisn, yes. I will be painting the walls. I will assume from your response (when I get it) , that a chair rail wallpaper border would incur the same procedure. I have learned over time that spot repairs are not conducive to a finished look.
Old 09-27-2011, 05:17 AM   #14
chrisn's Avatar
[quote=igneous;736502]In response to chrisn, yes. I will be painting the walls. I will assume from your response (when I get it) , that a chair rail wallpaper border would incur the same procedure. I have learned over time that spot repairs are not conducive to a finished look.[/quote]
You got that right. After removal and cleaning, prime the whole surface with the Gardz and you are ready to paint.
Tags
painting after wall paper
Painting after wallpaper removal tab13 Painting 3 10-02-2010 06:50 PM
Do I need to clean the walls before painting? EkS Painting 15 06-17-2010 11:54 PM
Looking for painting tips for interior walls mommytomyboys Painting 5 04-25-2010 08:08 PM
Painting dirty walls SimpleJack Painting 27 02-20-2010 08:51 AM
Painting interior walls of a new home shuss Painting 16 12-13-2009 09:28 AM
