Painting Walls - Painting - DIY Chatroom Home Improvement Forum
Old 04-28-2009, 12:25 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
painting walls
I just got done stripping my wallpaper, in some areas the top layer of the sheetrock came off, and in other areas, it looks like a little of the layer of paint can off, making the wall look like a bunch of "puck" marks.
I sealed all these areas over this Gardz wall repair.
I plan on doing two coats of primer and two coats of paint.
My question is if while doing the cutting in of the edges, if I were to put a layer of primer and/or paint on those spots, and then do the regular coats...would I be able to advoid the messy, time consuming job of joint compounding those areas for a smooth finish.
Barry
Barry J is offline   Reply With Quote
Old 04-28-2009, 01:31 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Unfortunately not. Neither the primer nor the paint will ever level the area out right. Joint compund really isn't that messy and when it's dry it will still wash out of clothes and off surfaces rather easily. Prime again over the joint compound.
Painting Interior Walls - Touch-up Job buzzer Painting 9 01-11-2012 05:30 AM
How to remove adhesive from painted walls before painting buffnrie Painting 3 04-27-2008 01:14 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
