Painting And Wallpaper Residue - Painting - DIY Chatroom Home Improvement Forum
Old 09-13-2009, 04:32 PM   #1
painting and wallpaper residue
So the house I live in has wallpaper in the bathrooms. Well the wallpaper seams were starting to curl up and show... so I thought it would be a good idea to remove the wallpaper and then paint over the walls. So I finally got ALL the wallpaper off the walls with some wallpaper removal solution. So now all the wallpaper is off the walls and I scrubbed and sponged the walls to remove the residue. Afterwards I felt the walls and they didn't feel like they had any residue on it.
Well I started priming the walls *the primer has a tint to it cause I'm using a darker color* by rolling it on and i notice that there is still some white showing through... I thought since I was painting grey over white this was normal and I would have to put on a second coat. Well once the paint dried I started painting over the second coat and I notice the first coat is starting to come off and not sticking. Clearly the glue residue is still on it. So now I have these walls with paint rolled on it and now I don't know what to do! What is the best way to remove the glue residue from the wall with a thin coat of primer on it?
here is a picture of the primer I'm using btw so you know what type of primer it is
http://img195.imageshack.us/img195/3269/img4132full.jpg
jayoshi is offline   Reply With Quote
Old 09-13-2009, 06:03 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Pitch, ditch or otherwise get rid of the primer. What you need is an oil based primer or Gardz
OOOLD wallpaper and painting Tab1975 Painting 7 04-07-2009 06:49 AM
Help! Painting Textured Wallpaper - Going Nuts! AbbyDabby Painting 6 12-13-2008 06:18 AM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
painting over wallpaper derose Painting 4 09-02-2006 03:56 PM
painting over wallpaper linda mcginness Painting 4 10-28-2005 11:56 PM
