Painting Wallpaper Covered Paneling. - Painting - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 03:02 PM   #1
Painting wallpaper covered paneling.
My bathroom walls are covered with factory made wallpaper covered paneling. Can I paint this if I prime it first? Will the wallpaper bubble up if I do this.
Avanell is offline   Reply With Quote
Old 03-11-2013, 05:46 PM   #2
ltd
Rewards Points: 536
of course with out seeing it I cant say for sure ,but I will anyways .no it should not bubble .I would go Zinsser's oil base cover stain ,get at the big box about 23 dollars. use a old or cheap brush then pitch brush and roller cover when done.caulk in gaps when primer is dry ,then 2 coats of good latex paint.
ltd is offline   Reply With Quote
Old 03-11-2013, 08:26 PM   #3
Rewards Points: 5,974
Remember oil based primer or Gardz Latex primer is water based and water canl cause bubbling.
Old 03-11-2013, 10:20 PM   #4
Roofmaster
Rewards Points: 2,172
Why don't you see what is under it and if its drywall just take it out? Its probably vinyl covered and you could end up with mold under it.
Old 03-12-2013, 04:52 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
I figured it was a mobile home
The Following User Says Thank You to chrisn For This Useful Post:
ltd (03-12-2013)
Filling holes in wood paneling before painting lahomerpair Painting 5 07-24-2012 04:52 PM
Priming before painting after wallpaper removal question spiceoflife Painting 6 09-11-2011 09:25 AM
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 05:25 AM
Painting soot covered walls syogod Painting 11 12-22-2010 12:37 PM
painting over wallpaper linda mcginness Painting 4 10-28-2005 11:56 PM
