Old 08-19-2005, 11:41 PM   #1
Question
Painting wallpaper
I have heard you can paint over wallpaper. Does anybody know the procedure? I'd like to texture over it first, then paint...
Thanx
imported_Linda is offline   Reply With Quote
Old 08-21-2005, 12:05 AM   #2
Painting wallpaper
If the wall paper is in good solid condition and not contact paper or a very glossy type surface. Then a good quality sealer should be all that is required to prep the surface after cleaning it good (a green scotch bright sponge while cleaning will work to give somewhat glossy paper some bite). After the prep you could the texture it. But I would seroisly think about the removal. Sometimes tough, but many times wall paper can come down fairly easily. Maybe try some in a small area and see how it is holding on.
http://discussdiy.com/showthread.php?s=&threadid=249
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-21-2005, 07:35 PM   #3
Painting wallpaper
Thank you so much. Will attempt to strip a piece first. If unsuccesssful will seal. What a great help you guys are! Love it!
Linda
