Painting This Wall - Painting - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 05:35 AM   #1
As you can see this wall is damaged. My initial procedure was to sand it down, and apply primer, and finally apply paint. This wall is exposed to damp. Firstly is the procedure correct ? If so, what kind of primer should I use ? and what finish of paint should I use ?
BijeshPatel is offline   Reply With Quote
Old 06-02-2012, 08:41 AM   #2
Why can I not view the pictures? It tells me I don't have sufficient permissions or my account is waiting activation.
Old 06-02-2012, 08:47 AM   #3
Rewards Points: 12,878
It's doing the same thing to me, so it's not just your system. It's also not letting me post replys on some post and I have notified them about the problum.
Old 06-02-2012, 06:31 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 146
me too
Old 06-02-2012, 06:53 PM   #5
Rewards Points: 256
Was it something I said?
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 06-04-2012, 01:04 AM   #6
can't view pics here either...
pucks101 is offline   Reply With Quote
Old 06-04-2012, 04:57 AM   #7
chrisn's Avatar
Rewards Points: 146
They are there today
Sand smooth, clean, apply Gardz, skim coat , sand, clean, apply Gardz,( or other primer) paint
Can I remove this wall? limited60 Remodeling 9 06-05-2012 02:32 AM
Painting half of a wall silversport Painting 2 03-30-2012 04:49 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
