05-19-2012, 07:58 AM
#1
Painting waferboard
Im in the process of finishing my shed, theirs some wafer board that will be exposed that i will like to paint white.
My questions is, can i use spray paint to paint the wafer board faster, or do i have to buy the real paint and primer. Also what type of paint do i use for exterior use.
05-19-2012, 08:14 AM
#2
Painting waferboard
Are you sure you do not mean OSB instead of wafer board?
It should never be left exposed, painted or not. Over time it will start to degrade.
How about posting a picture.
05-19-2012, 09:04 AM
#3
jschaben
Painting waferboard
You can use spray paint, you will just use a lot of it as it needs a good coat of primer and paint. All the little grooves need to be filled in. Rustoleum is usually pretty good for exterior use. Check the can but most is recommended for either wood or metal. Also, all rattle can stuff you will need to strictly adhere to dry times and especially recoat times.
John Schaben
"Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-19-2012, 09:12 AM
#4
the Musigician
Painting waferboard
I have a "temporary" shed that's been up for 7 years and is raw OSB, no paint or anything and it's still there... The only reason I would have for siding it is if I want to keep it there and have it insured. It depends upon many factors as to what you can do with it.
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
05-19-2012, 02:22 PM
#5
Painting waferboard
Is their rustoleum primer? Also, can paint itself fill in the spots in the waferboard or do I use something else?
05-19-2012, 05:03 PM
#6
jschaben
Painting waferboard
Yeah, Rustoleum has a primer, they also have top coats. Rustoleum corporation is a pretty large outfit, own several brands. No, the paint wont fill in all the holes completely to give a glass smooth surface. If you wanted that, you wouldn't be using the stuff in the first place. It will penetrate into the cavities and provide moisture protection.
John Schaben
05-19-2012, 05:19 PM
#7
Painting waferboard
Is their something i can use to fill in the gaps? Or do i use some other material then? Should i just use plywood then for those finishes?
05-19-2012, 05:44 PM
#8
Painting waferboard
If you would post a picture of what your trying to do I'm sure you would get better ansewers.
If it's trim then no, do not use plywood, use vinyl lumber for 0 maintaince, or Fir, Cedar, or even Kiln Dryed Yellow pine.
05-19-2012, 06:02 PM
#9
jschaben
Painting waferboard
I don't know what kind of look you are going for. I suppose you could skim coat it wood filler and sand it out to get a smoother look. Plywood would start out smoother. It is just a shed so unless you have a particularly anal homeowners association, just paint should be adequate.
John Schaben
05-19-2012, 06:16 PM
#10
Painting waferboard
Im trying to copy the finishes of the roof of this shed, it has exposed plywood on the roof and the sides.
05-19-2012, 08:23 PM
#11
jschaben
Painting waferboard
OK.. that's a pic of what you're going for, how about a pic of what you've got. Can figure it out much better then.
John Schaben
05-19-2012, 08:39 PM
#12
Painting waferboard
Well... I got the roof framed for that plywood to overhang a bit, I am goin to install the waferboard on the roof tomorrow and spray paint the roof before I put shingles and sidings( a lot easier to paint before I install that)
05-19-2012, 08:55 PM
#13
Painting waferboard
Nm. read the rest of the posts.
05-20-2012, 03:55 AM
#14
paper hanger and painter
Painting waferboard
If it's trim then no, do not use plywood, use vinyl lumber for 0 maintaince, or Fur, Cedar, or even Kiln Dryed Yellow pine.
muskrat, beaver, fox, ermine, mink, rabbit?? which one would be best?
05-20-2012, 04:00 AM
#15
Painting waferboard
Maybe I am just dense( probably) but why would you paint the "waferboard"(what ever that is) and then put shingles over it???
The Following User Says Thank You to chrisn For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
