Painting "W" First - Painting - DIY Chatroom Home Improvement Forum
Old 12-09-2012, 03:11 PM   #1
jho
jho's Avatar
Painting "W" first
Just out of curiosity, whenever I see paint ads advertised on tv for Sherwin Williams or Home Depot, they always show the models painting a big W on the wall. And they start in the middle of the wall. What's the meaning of this? I've been painting for 10 or so years, have worked for many paint companies, and was never shown to paint this way. I figured it's to simply get the paint that is soaked on the roller off in the middle of the wall, then to distribute all that paint throughout the wall to prevent drips at the bottom sweep of the roller by the floor boards, but I've always started either left to right, or right to left.
jho is offline   Reply With Quote
Old 12-09-2012, 03:32 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
I don't get it either. The ads must be made by ad men, not anyone who has a clue about painting.
First- a frame should be on a pole so you can make an even stroke from top to bottom in one clean pass.
Load roller well - i like to start on the up stroke and make a "slight " angle equal to 1.5 width of the roller. Go up and down spreading this evenly through that area. End with straight strokes from top to bottom.
Should be a total of about 5 passes through the area. Overlap the next one by half of a roller.
NEVER hold the frame in your hand on a full wall. Complete waste and inefficient.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-09-2012, 08:48 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
The W stands for Rookie.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Gymschu (12-10-2012)
Old 12-09-2012, 09:52 PM   #4
Rewards Points: 5,974
I will explain it to you the way it was explained to me. If you dip your roller then start painting left to right your first couple rolls will be with a fully loaded roller as you move to the right now there is very little paint in your roller so you dip again. Where you left off the paint is now light . when you start again it is heavy. In a lot of lights these will show as stripes. When you put the big W or M or whatever then you go back and even it out it will eliminate this effect. I believe this happens more with DIY than pro simply because pro knows to look out for it. JUst what I was taught, judge for yourself.
The Following User Says Thank You to ToolSeeker For This Useful Post:
ashleyamazi (12-09-2012)
Old 12-09-2012, 10:55 PM   #5
Ok, first off, I am a complete newbie and it's about to show... But what is a frame? I'll be painting soon and definitely don't want to be wasteful or inefficient.
ashleyamazi is offline   Reply With Quote
Old 12-09-2012, 11:19 PM   #6
The thing you put the roller cover on.
sorta like this
Old 12-10-2012, 05:55 AM   #7
I wondered this too. But, if you think about it, the pattern of rolling is in the W or M shape, what they show is an extremely literal form of the letters/idea. Toolseeker had it right when he said the first effort is to spread the roller load over the width of the move, then up and down to cover, then back and forth/back into to layoff. When you're doing that you're actually making an abstract M or W. Watch for it next time you're rolling.
The Following User Says Thank You to jsheridan For This Useful Post:
ToolSeeker (12-10-2012)
Old 12-10-2012, 11:57 AM   #8
Rewards Points: 736
If you read any DIY / novice painting advice, it almost always says "start by painting a W and then spread paint out from there." I don't think I've ever seen a HowTo that DIDN'T say that. Im sure it's not how the pros do it, but the average person buying paint from Home Depot is NOT a pro, and isn't going to spend or work like a pro.
I'ts amazing to me how many people on the DIY website are pros who look down on those who DIY.
TheBobmanNH is offline   Reply With Quote
Old 12-10-2012, 01:53 PM   #9
Who bob I sure haven't noticed it buy maybe m too close.
Old 12-10-2012, 02:22 PM   #10
So Bob- is explaining a more efficient way to paint that every painter that has painted for more than a week uses looking down, or informing?
Go read my post, then go to see it for real here.
Knowledge is power.
or
http://www.youtube.com/watch?v=flwNHJ-t5d
Old 12-10-2012, 02:38 PM   #11
Rewards Points: 736
Knowledge is power.
or
No sir, I appreciate your input.
The "the 'w' is for rookie" comment just got me to thinking about all the similar posts I stumble upon from professionals. I love the constructive posts some of you guys make, and even the good-natured ribbing about those of us who don't know what we're doing, but sometimes it doesn't come off as good-natured so much as resentful. Tough to gauge online, I guess, so I could be just mis-interpreting.
Old 12-10-2012, 05:45 PM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
That guy had more paint on his pants than on the wall
Old 12-10-2012, 06:05 PM   #13
Not like the HD girl wearing all black, no drop cloths and holding the roller frame, making a W... he must be good! lol
Old 12-11-2012, 11:20 AM   #14
jho
jho's Avatar
We were all rookies of a trade at one point of our lives, and though some of you may be veterans of your trade, I'm sure you still seek advice from pros of other trades for projects you're working on to save on labor costs. If I would have known posting this thread up would have sparked that kind of a response, I wouldn't have asked. I mean, come on people, this is a DIY'er site, where inexperienced people come to seek advice from professionals. I was simply just asking to see if other pros have seen this and are using this strategy on a regular basis
Old 12-11-2012, 11:27 AM   #15
jho
jho's Avatar
Thanks brushjockey, toolseeker and jsheridan for the answers I was looking for. Good luck ashley with the painting!
The Following User Says Thank You to jho For This Useful Post:
ToolSeeker (12-11-2012)
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
painting my mom house supaflyz Painting 5 07-28-2009 03:34 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
