Painting Vinyl Windows - Painting - DIY Chatroom Home Improvement Forum
Old 08-03-2008, 05:18 PM   #1
Painting vinyl windows
2 questions please.....I have Anderson Windows the Terratone color which has faded pretty badly since installed in 1983. Can I paint successfully over it with Duration exterior latex?
Also, The flat channel that seats over the edge of the glass is peeling & popping out. Any ideas on a substitute besides what I probably can order from Anderson to caulk or glue or secure them back in? Thank you in advance.
Wisco is offline   Reply With Quote
Old 08-03-2008, 10:00 PM   #2
Rewards Points: 2,906
Any latex or alkyd paint will stick well to vinyl, so I don't see a problem painting vinyl.
The reason why window manufacturers make all their windows in WHITE vinyl and don't recommend painting them is because vinyl softens up a lot with increasing temperatures. And, if you have soft vinyl and a strong wind blowing on a hot window, you can permanently stretch (or otherwise deform) the vinyl so that the window won't close properly after that.
With vinyl siding, making it in only white and telling people they can't paint it was a non-starter, so manufacturers of vinyl siding tell people not to paint their siding any darker a colour than it originally was. Otherwise, it could get so soft on a hot day that it'll sag under it's own weight and such deformation will be permanent.
So, if you do paint your windows, don't paint them any darker a colour than they originally were. And, it'd be best if you painted them white to keep the vinyl as cool as possible on a hot sunny day.
Nestor_Kelebay is offline   Reply With Quote
Old 09-24-2008, 10:26 AM   #3
http://www.contractortalk.com/showth...PAINTING+VINYL
CHECK OUT THIS TREAD i have had no luck . when windows are painted from the manufacturer if scrathed they go back to white?
all vinyl is offline   Reply With Quote
Old 09-24-2008, 12:04 PM   #4
Rewards Points: 506
I don't know how applicable this is to windows, but Sherwin has a specific color palette for Vinyl siding. I think it maybe avoids using pigments that are not compatible with Vinyl. It may be worth a look.
SirWired
sirwired is offline   Reply With Quote
Old 09-24-2008, 05:57 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Yes
If properly cleaned Duration should stick OK
Also please keep in mind that Anderson has changed their Terratone over the years, so if the SW store has a formula for Anderson Terratone on file, it may be a match to the latest, or a later vintage(s)
You might want to find a SW color that you like and use that
slickshift is offline   Reply With Quote
Old 09-24-2008, 07:57 PM   #6
Replacement Windows
It is best not to paint vinyl windows if you can get away with it but if you can pick a almond or beige color that would be your best bet...
This is a good article to check out on the topic:
http://www.demesne.info/Improve-Your...yl-Windows.htm
Last edited by AtlanticWBConst.; 09-24-2008 at 08:06 PM. Reason: Site Rules Violation: Advertising Links Removed From Signature
replacementwindowsguru is offline   Reply With Quote
Old 09-24-2008, 11:25 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Vinyl is the same color/material all the way through. If you surface is faded, try sanding the surface with some 400 or 600 grit sandpaper and then clean it with maybe some denatured alcohol.
Old 01-05-2010, 05:04 PM   #8
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Painting Vinyl Siding
Yes, you can use Duration. I prefer SW Superpaint, but both of them are vinyl safe, they both are 100% acrylic and have vinyl safe technology to move with the expansion and contraction of the vinyl, they will also not cause the vinyl to buckle or warp, Not every latex can be applied to vinyl, in general a 100% acrylic that has vinyl safe technology should be applied, because it will expand and contract better with movement, not buckle or warp the siding. You do not want to use an oil base, oil bases have no flexibility to expand and contract. We paint vinyl siding and trim, usually we use SW Superpaint, we warranty our work against peeling, flaking and chipping and have never had a problem.
Vinyl can be painted darker colors now days with the right paint, SW Duration and Superpaint are formulated to paint vinyl darker colors than the original color without buckling and/or warping.
housepaintingny is offline   Reply With Quote
Old 01-05-2010, 05:58 PM   #9
Rewards Points: 616
http://www.kelloggspainting.com/Exte...ePainting.html
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
Window Casing around Vinyl Windows tcoshea Building & Construction 3 11-28-2007 09:52 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Vinyl Siding & windows question blazermaniac General DIY Discussions 6 04-08-2006 12:47 PM
