Old 04-29-2012, 11:44 AM   #1
painting vinyl on windows?
lets just say, for the sake of arguement, that a new vinyl window needed to be painted. what would be the way to do it ? not looking for a perfect finish. but would like it to last.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 04-29-2012, 11:47 AM   #2
Tom Struble's Avatar
inside or out?i know manufactures will custom paint the outside of vinyl windows,how or what i don't know
Tom Struble is offline   Reply With Quote
Old 04-29-2012, 11:48 AM   #3
How you you paint the deviders if there is any.
Vinyl can be lightly sanded, cleaned off and use a bonding primer and Acrilic Latex paint.
Old 04-29-2012, 11:54 AM   #4
perhaps both
no deviders.
i have 1 basement slider window that is not old and is in good shape.
i want to get the same window, as much as is possible, to replace 2 other OLD windows. and i am thinking i would like to make them all the same color =NOT white.
Old 04-29-2012, 11:57 AM   #5
If it's a new window then some manf. have differant colors they can come in so there's no paint to worry about.
Old 04-29-2012, 12:02 PM   #6
i found this [click read full article tab] don't know if it helps,maybe check with the window manufacturer
http://www.calfinder.com/magazine/wi...can-be-painted
Old 04-29-2012, 12:05 PM   #7
besides the 3 or 4 solid color choices they have,they can custom paint the outside also
Old 04-29-2012, 12:13 PM   #8
yeah, but i would still have to paint the window i have now. and i believe i saw the same exact window on the shelf at manards. so no ordering.
Old 05-02-2012, 09:39 PM   #9
We have vinyl trim around our exterior doors and I painted it without problem. I used exterior latex and it seems to be adhering fine. I didn't sand or prime, but YMMV.
Michaelpro is offline   Reply With Quote
Old 05-06-2012, 07:57 AM   #10
I had a contractor damage the exterior of my vinyl windows. He used automotive paint (bumpers) to fix the damage. Windows are dark brown. Worked very well. Still no issues after five years.
Earnie is offline   Reply With Quote
Old 05-06-2012, 11:13 AM   #11
idk yet. but i think i am just going to replace all of them. my house is all white = i hate that.
Old 05-07-2012, 09:58 AM   #12
Windows & Remodeling
HomeSealed's Avatar
If you are replacing all of them then get a good window with a factory paint coating. The windows sold at menards are "shed-worthy" for the most part. Painting can be done diy but it will void most warranties.
HomeSealed is offline   Reply With Quote
Old 05-07-2012, 09:30 PM   #13
this is the basement windows. and idk if i "should" put a "good" window down there. i would rather replace a broken $100 window. than a broken $200 window, that i have to drive across town to get. 24x30" sliders. unheated, unless i get the fireplace going.
Old 05-08-2012, 10:36 AM   #14
Drywall and Painting Pro
Sir MixAlot's Avatar
I have painted windows before. I used spray can metal primer and then a spray can of semi gloss metal paint.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Vinyl replacement windows - RBS Performance Plus? heavyharmonies Building & Construction 8 09-01-2010 04:48 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
vinyl windows, replace or not? leetyson General Discussion 4 08-08-2009 09:38 PM
Vinyl replacement Windows AdRock Remodeling 9 08-05-2009 09:56 AM
Frost on interior of vinyl windows d.sharkey Building & Construction 8 07-06-2009 07:25 PM
