Old 01-04-2008, 11:50 PM   #1
Painting Vinyl Sliding Glass Doors
In order to get the type of sliding glass patio door I want (blinds between glass) and stay on budget, it looks like my choices will be vinyl construction with a a choice of one color: white. Door manufacturers say "Do Not Paint" the vinyl. My particular installation will be north facing and shielded by a trellis so it will receive no direct sunlight. Can the vinyl be successfully painted a medium tan color? If so, what kind of primer and paint should I use? I remember seeing info on some special vinyl paint awhile ago but can't seem to find it anywhere.
Thanks,
Idaho Bob
IdahoBob is offline   Reply With Quote
Old 01-05-2008, 06:57 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Follow the manufacturers recommendations on this one
slickshift is offline   Reply With Quote
Old 01-05-2008, 09:55 AM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,.....
Generally speaking,... Vinyl is Much too Slippery to hold Paint,....
Even with proper Sanding,... It'll just shed the paint with Time......
You Can paint it, but be prepared to watch it Fall Off......
Old 01-05-2008, 10:23 AM   #4
There are primers and paints certified for Vinyl siding, but I just don't see that magically working to stick to a vinyl door frame. The vinyl door frame will have a lot of flexing and movement that is not an issue with siding.
The biggest problem with trying is that you are going to have to remove every speck of paint if you don't succeed unless you want it to look even worse.
SirWired
sirwired is offline   Reply With Quote
Old 01-05-2008, 03:56 PM   #5
slickshift's Avatar
Yup
You can paint a fish if you want to
Doesn't mean it's a good idea
Old 01-05-2008, 05:34 PM   #6
Pro Painter
It can be painted.
You need to find out exactly what type of vinyl it is. Typical siding and shutters are pvc - polyvinyl chloride, which is easily paintable.
Different types of vinyl can still be painted, but you need to know which type you have.
joewho is offline   Reply With Quote
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 09:49 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
Sliding Glass Doors Drewimus General Discussion 2 10-02-2006 10:06 PM
Help!! Removing sliding doors? luo2000 General Discussion 11 04-10-2006 12:10 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
