Painting Vinyl - Painting - DIY Chatroom Home Improvement Forum
Old 08-01-2012, 01:42 PM   #1
painting vinyl
Can i use a darker colour on my vinyl if i use Sherwin Williams
dogpatch is offline   Reply With Quote
Old 08-01-2012, 04:35 PM   #2
Gymschu's Avatar
Rewards Points: 476
There are some darker colors in the SW paint line that are useable on vinyl siding. I would talk to the sales pros there to make sure.
Old 08-01-2012, 04:45 PM   #3
Rewards Points: 13,274
There's a reason why you almost never see vinyl in a dark color.
It expands a lot when it gets hot, it can get so hot it starts to buckle.
It also will faid far faster painted a dark color.
One more fun fact, if you were to paint it now while it's hot there's going to be strips any place where the pieces lap.
Can vinyl siding be painted sure, will you like the look after a few seasons of it expanding and contracting, not likly.
Sherwin Williams Duration or there Super Paint will stay stuck the best.
Make sure it's clean before painting.
Old 08-01-2012, 06:55 PM   #4
Gymschu's Avatar
Rewards Points: 476
Joe, you mention the overlap areas expanding and exposing the old color when it gets hot. I agree that does happen but a really good painter can work magic with his paint brush and actually paint UNDER that overlap so that when it expands, the old color does not show up. Just wanted to point that out. It does take a bit of extra work to accomplish that, but it can be done.
Old 08-01-2012, 08:17 PM   #5
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Sherwin Williams does have vinyl safe colors and some are darker, especially when using Duration. When you paint vinyl or aluminum siding the key is to make sure the surface is cleaned well, dry and you want to paint when its hot, because that's when the siding is expanded. Painting when the siding is expanded will reduce your chances of having those marks at the joints that Joe is speaking of. We paint both vinyl and aluminum siding all of the time with no problems using Sherwin Williams products.
housepaintingny is offline   Reply With Quote
The Following User Says Thank You to housepaintingny For This Useful Post:
Gymschu (08-01-2012)
painting vinyl shutters diy96 Painting 0 10-13-2010 10:46 AM
Decorative Painting on vinyl placemats CarlDan Painting 0 09-21-2010 07:11 PM
Vinyl Siding Versus Painting Asbestos freedom_fighter Remodeling 3 02-27-2009 11:35 PM
Painting Vinyl Coated walls WiccanOne Painting 8 02-17-2009 10:28 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
