Painting Varnished Kitchen Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 08:15 PM   #1
Rewards Points: 150
Painting varnished kitchen cabinets
Is there a method to 'prep' the surfaces so that the paint will bond, or is stripper and sanding the only options? I'd also like to paint the door frames rather than replace.
Image below. Thanks for any suggestions.
rightit is offline   Reply With Quote
Old 11-26-2012, 12:49 AM   #2
Rewards Points: 13,300
A whole lot of work but to get the paint to stay stuck there going to have to be degreased, stripped ( I would use a random orbital sander not a stripper)
primed with a bonding primer and two coats of finish paint.
May want to stop by your local real paint store and ask them what to use for a primer and paint. And no Home Depot and Lowes do not count.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Hammer450R (11-26-2012), rightit (11-26-2012)
Old 11-26-2012, 08:04 AM   #3
Rewards Points: 150
Originally Posted by joecaption
A whole lot of work...
I was afraid of that . I somehow forgot to mention that the front of the doors have a veneer. Sand or strip?
ALso, I'd really rather not remove the cabinet frames from the wall (or I may as well bite the bullet and replace them! The doors, of course, come off.). Possible?
Thanks again .
Old 11-26-2012, 09:11 AM   #4
Rewards Points: 150
That is the single best advise i have seen on these forums lol
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 11-26-2012, 09:23 AM   #5
Too Short? Cut it Again!
Nonsense as usual. Joe is not a painter and is sometimes to quick to comment without thinking his responses.
You do not have to strip them so long as you remove any varnish that is chipping or flaking. You do have to degrease them and really clean them to remove any wax buildup that might be on them. You will need to fill in and out any surface imperfections.
Scruff the surfaces with fine grit sandpaper. Apply a quality bonding primer/underlay and then two coats of quality paint store finish.
If budget allows, think about upgrading the hardware.
The Following 2 Users Say Thank You to user1007 For This Useful Post:
Expert Paint (11-28-2012), rightit (11-26-2012)
Old 11-26-2012, 09:24 AM   #6
There's some other options to make those cabinets look better.
You could buy all new doors, and drawer front's that look better then those flat panels.
There's hudreds of on line companys that do nothing but make the doors and fronts.
You could replace all that old hardware and add some nice trim to the faces of the doors to make them look like recessed panels.
Could do what's called picture framing on the face of the doors.
rightit (11-28-2012)
Old 11-26-2012, 09:28 AM   #7
Rewards Points: 150
Dude you said the same thing he did????
Old 11-26-2012, 09:55 AM   #8
Certainly did not! Here is his quote. We did agree on the need for primer and finish.
"A whole lot of work but to get the paint to stay stuck there going to have to be degreased, stripped..."
They do not have to be stripped if they are going to be painted.
Old 11-26-2012, 10:21 AM   #9
Rewards Points: 5,974
Just use a deglosser, scuff the surface, I would prime with BIN just in case of tannins and good quality paint (2 coats)
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 11-26-2012, 12:42 PM   #10
Rewards Points: 150
forgot this part..."( I would use a random orbital sander not a stripper)"
Old 11-26-2012, 12:48 PM   #11
Lost you bubba. He is still suggesting the cabinets need be stripped but using a random sander and not a chemical stripper? Maybe I read it wrong. The suggestion to strip completely by any method is irrelevant. You don't need to do it to paint. If you are trying to get to the wood so you can re-stain, the game changes.
Old 11-26-2012, 01:38 PM   #12
Rewards Points: 150
Thanks for all of the responses. No stripping or sanding gets my vote!
Any recommendations on the degreaser or any additional cleaning supplies/method (or a URL outlining proper procedure & materials)? The guys at BM should be able to help with paint and primer recommendations, but I wouldn't put my nose up at any suggestions offered here.
Oh, and if anyone is willing to just come do the job...
Old 11-26-2012, 04:28 PM   #13
Rewards Points: 39
I did this very thing, two different ways. For the upper cabinet doors, I TSP'd them and sanded them down. Then used Zinnser primer and latex paint and added some picture framing. It's held up for 2.5 years now. On the bottoms, I went the deglosser route. TSP again, deglosser, prime, then paint. So far, those have held up for 9 months now.
Plump is offline   Reply With Quote
The Following User Says Thank You to Plump For This Useful Post:
Old 11-26-2012, 04:47 PM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
how far south east of Maryland are you?
I am going to jump in here
You DO need to sand everything after cleaning.
Forget the deglosser
Clean with Dirtex
Lightly sand all surfaces with 120 grit paper
Apply a quality bonding primer( Cover Stain, Zinnser 123),Bin would be over kill
Apply 2 finish coats
The Following User Says Thank You to chrisn For This Useful Post:
Old 11-26-2012, 04:53 PM   #15
Rewards Points: 150
Well, any farther and I'd be soaking wet!
I stand corrected. When I said no sanding, I was referring to sanding down to bare wood. Thanks for the heads up.
Clean with Dirtex
And thanks for the detail.
Painting kitchen formica cabinets? Startingover Painting 2 05-13-2012 05:40 PM
Advice for painting laminate kitchen cabinets Grammykt Painting 2 03-12-2012 05:58 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 07:21 PM
Painting kitchen cabinets buckwillis Painting 7 08-23-2008 09:42 AM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
