Painting Two Coats - Painting - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 05:36 PM   #1
painting two coats
I will need two coats of paint. Should I cut in and then roll and repeat or can I do two coats of cutting in and then two coats of rolling?
jstro is offline   Reply With Quote
Old 03-15-2012, 05:42 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Somewhat depends on the paint and sheen-
Typical would be cut first -roll- repeat.
Some newer paints you can cut in and let dry- then roll- some you need to roll into while the cut is still wet-
More info about what you're using needed.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-15-2012, 06:00 PM   #3
Gymschu's Avatar
Rewards Points: 1,014
The professional approach is to cut in, roll first coat, allow to dry. Repeat process for best coverage and to eliminate "hatbanding" and "holidays" or any type of lap marks.
Gymschu is online now   Reply With Quote
Old 03-16-2012, 09:20 AM   #4
two coats
I figured I'd have to do it all and then repeat, but I was hoping to get the brushwork done and then go to rolling. Oh, well. I am using Ben Moore eggshell finish...cream over gold color. Thank you!
Old 03-16-2012, 10:06 AM   #5
Which line in BM? If Regal Select or Aura- you can and should cut in, let dry- then roll. ( But roll close)
Regal regular can be in lighter colors, but in darker ones it is better to roll into a wet edge.
Same with Ben, Super Spec.
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 10:42 AM
painting project, large home interior - need planning help bokeh Painting 9 11-06-2010 09:45 AM
painting dark from light, how many primer coats? Miss Molly Painting 6 05-20-2009 10:04 AM
2 coats versus 3 coats joeyboy Painting 9 08-24-2007 11:43 AM
Be honest, do you really do three coats on everything? KUIPORNG Remodeling 18 03-30-2007 03:02 PM
