01-04-2009, 12:07 PM
#1
painting trim and base boards
Hey everyone. I currently have wood trim in a wood color and im thinking about giving it some white along with the doors also. i would rather pop off the trim and paint them in the garage but when i put them back on i dont feel like nailing the trim and having the hammer chip the fresh paint... should i do them while they are installed? i rather not this way it looks better.
01-04-2009, 05:53 PM
#2
I'd be very reluctant to paint wood stained trim. It's maintenance free now, and it goes with any wall colour just the way it is. If you paint that trim, the next time you paint the walls, you'll be saying "Now I need to paint the trim, too."
However, if you choose to paint, I would paint the trim in place. Just use masking tape to tape the trim off so you don't get paint all over the place. Removing the trim to paint it separately is going to result in your having to pull the nails AND probably patch some plaster that'll come out in chunks near where the nails were. If you do that, pull the nails out from the BACK of the trim so as not to muck up the varnished front face of the trim.
If this trim is varnished, you should dull the gloss before painting it. This can be done by cleaning the trim with a solution of TSP in water. If the paint on the walls is a latex paint, you don't have to worry about harming the paint. Latex paints aren't affected by TSP. However, I have heard that you can permanently stain floor tiles with TSP. I've never tested that to check, but if you're using TSP over a ceramic tile floor, then either test the TSP in an inconspicuous spot, or throw down some plastic and cover with blankets or something.
Bashing my head against the walls in some of the internet's finest chat rooms.
01-04-2009, 07:15 PM
#3
thanks for the reply, i was thinking about leaving it but i really like the white trim. but i would like to see some pictures on tan walls with wood color trim or like a pale yellow with same trim. thanks though
01-04-2009, 08:22 PM
#4
I would leave it in place. I did that with my upstairs base and door trim, which were stained chestnut. Scuff it up, prime, 2 coats of paint - sanding in between.
My downstairs we replaced the chestnut stained wood and spray painted 26 6-panel wood doors. Fun.
Here's a pic;
Taking the trim off without damaging it could be difficult.
01-04-2009, 11:23 PM
#5
Here's a pic;
look so much cleaner, nicer and stylish with the white trim... mmmmmm
01-04-2009, 11:36 PM
#6
It does.
Painting the stained trim was a pain, but it came out well. The only thing I would recommend is 2 coats of primer.
01-05-2009, 12:42 AM
#7
It does.
it looks great...did you use oil or latex? I have used oil in the past and it worked well.
01-05-2009, 06:31 AM
#8
Yes, you can paint that trim just fine, but I am going to disagree with Nestor's advice to use tape. Tape usually has the problem of bleed under the edge, making it look much worse than if the tape was not used at all.
Use oil-base primer to coat that stained trim. On top of that, the Waterbourne enamels from SW or BM (ProClassic or Impervo) do a fantastic oil-like job without the drawbacks of actual oil paint.
SirWired
01-05-2009, 07:33 AM
#9
I go the easy route (for me) - latex.
12-30-2009, 11:05 PM
#10
Sandy - Your photos look great. I have a house full of this trim and am considering painting it. Do you have any other photos of your work that you can post? thxs! t
Here's a pic;
12-31-2009, 08:34 PM
#11
thank you! Unfortunately, the hubby and I were so burned out with this project, I haven't worked on any other for quite a while.
Here are a couple more;
We put in all the crown, wainscoting and replaced the baseboard with taller base. Left the staircase as is.
The previous pics of the door. That is all new work, except for the little bit of chestnut trim around the door - everything else, base, jambs, header, crown, columns and wainscoting - all new.
I painted all the chestnut trim in the upstairs - doors, base, door trim.
In the family room;
We replaced all the base and door trim, but painted the doors and added the crown and column moldings.
03-12-2010, 08:34 PM
#12
a colum like this to make the space look wide
03-13-2010, 05:52 AM
#13
paper hanger, painter
It does.
Why?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
