Painting Trim - Painting - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 08:21 AM   #1
Painting Trim
I'm breaking this out since perhaps it is buried in the longer post. We're repainting the dining room/living room space.
The trim and wood work around the base, windows, arches, etc... I think it was painted glossier than everything else, but I have no idea what it was. I do want to prep it so that this painting job works though. Sand it? Someone mentioned a special primer or deglosser to bridge the possibly different paint types?
Advice?
Reignwater is offline   Reply With Quote
Old 09-02-2010, 08:30 AM   #2
220 grit sand paper, Sand to scuff. Use primer, Top coat. There are short cuts, but that will effect your end result..........
mark942 is offline   Reply With Quote
The Following User Says Thank You to mark942 For This Useful Post:
hammerheart14 (09-02-2010)
Old 09-02-2010, 09:34 AM   #3
Rewards Points: 558
If itís a high gloss finish then you can use TSP to clean and de-gloss the trim and then use an oil based primer then you can either use an oil base or latex finish coat with no problems.
epson is offline   Reply With Quote
Old 09-02-2010, 10:24 AM   #4
Rewards Points: 526
Advice?
Sand with 150 - 220 grit paper and use a latex primer. If adhesion is an issue, use a latex bonding primer. This is a very effective method for interior applications.
Windows is offline   Reply With Quote
Old 09-02-2010, 10:41 PM   #5
Rewards Points: 150
YES. I concur!!!!!!
hammerheart14 is offline   Reply With Quote
A couple questions (edging & trim painting) cellophane Painting 20 01-14-2010 05:23 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 07:00 AM
