Old 02-08-2009, 05:32 PM   #1
Painting Trim
I have trim that was originally stained. Later it was painted. The paint is popping off. I want to repaint the trim. What is the best way to sand the trim before priming?
gbvestal is offline   Reply With Quote
Old 02-08-2009, 05:47 PM   #2
the Musigician
DangerMouse's Avatar
Painting Trim
do you mean sand it to remove the flaking paint? if so, try a putty knife or chisel to CAREFULLY pull off as much paint as possible. is the trim baseboards? crown moulding? is there a surface pattern cut in? if so, perhaps Strypeeze first? we'd need more info on the trim or perhaps pics to help you more.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 08:15 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 09:18 PM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 08:00 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 11:16 PM
