Painting Trim - Painting - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 06:08 AM   #1
Rewards Points: 264
painting trim
I am installing new base and shoe. Pre-painted 2 coats of semi-gloss. I filled the nail holes with DryDex.
Should I spot prime the nail holes or just go over them with the top coat?
7echo is offline   Reply With Quote
Old 02-28-2012, 06:34 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
What paint are you using? It will probably take 2 of whatever to keep the mud from sucking the sheen out of the paint. with most paints now you could use the finish twice or prime and finish. If you use a primer , just make sure that the finish has good enough coverage to cover the primer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-28-2012, 08:19 AM   #3
Rewards Points: 264
The paint I am using for the trim is BM Super Spec.
Old 02-28-2012, 03:07 PM   #4
Workaholic's Avatar
Rewards Points: 268
I would prime them, spackles like drydex tend to flash. I use Crawfords painters putty for nail holes.
Sean
Workaholic is offline   Reply With Quote
Old 02-28-2012, 06:21 PM   #5
Rewards Points: 512
ya prime the spots then put the semi gloss on. i use glazing putty for mdf trim, drydex take atleast 2 coats dry time and a light scuff
princelake is offline   Reply With Quote
Old 02-28-2012, 06:45 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Prime before painting. In the future if you fill nail holes in trim use a painters putty or glazing. Dry dex and joint compound materials are not the best choice to fill nail holes in trim with. I use painters putty and some times glazing.
housepaintingny is offline   Reply With Quote
Old 02-28-2012, 08:55 PM   #7
Rewards Points: 264
Thanks for the replies. I have a bit more to do and will get the putty.
Old 02-28-2012, 09:39 PM   #8
7- one thing about both the Painters Putty and glazing ( dap 33..)
They are really oily when new. I usually take a ball of it that is what I think i will need and work in a little powdered mud to dry it out a bit. Because I always have the powder- it's no big deal. you can also get a little box ( looks like a little milk carton) of whiting which will do the same thing. Hard to work with without making it a doughlike consistency, just on the edge if being sticky.
Old 02-28-2012, 11:24 PM   #9
Workaholic's Avatar
Rewards Points: 268
Good advise. I do the same thing but failed to mention it.
Sean
Old 02-29-2012, 04:58 AM   #10
I've used baby powder in a pinch, it smells nice too. My go to for nail holes is lightweight vinyl spackle. Overfill the holes and sand smooth during your normal sanding prior to finishing. Very little shrinkage, no flash after two coats, no smiles. It's the best method I've ever found.
painting trim with semi gloss paint sninny Painting 10 09-21-2012 04:33 AM
Painting over stained wood baseboard & trim Leenders Painting 6 02-23-2011 08:50 AM
Painting over trim wriegler Painting 2 11-22-2010 11:40 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Spray painting interior trim to look like glass. sprayer48 Painting 2 04-15-2008 07:15 PM
