Old 08-25-2007, 04:06 PM   #1
Question
painting tile
My fireplace surround is an gray-white ceramic tile (12"X12" squares) and it looks very cold. I would like to "warm" it up by painting it to look like Saltillo tile, which would also make it a focal point for the room. DIY tips tell me to clean it, then sand with an orbital sander, prime and paint 2-3 coats, then allow to cure. Has anyone tried this and does it work?? If the paint is going to chip, then it will look horrible, so I want some assurance that it CAN be done before I jump in! Also, do I really need to use OIL base primer/paint?
cecek is offline   Reply With Quote
Old 08-25-2007, 04:39 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
painting tile
It can work
It doesn't always
Therein lies the problem
I'd use pigmented shellac (BIN) or a bonding primer (XIM)-latex primer will NOT cut it-and the best enamel (paint) you can get
Do not use the "big box" tile painting kits-they are poor quality and have extremely high failure rates
slickshift is offline   Reply With Quote
Old 08-25-2007, 04:52 PM   #3
painting tile
I think the project is more likely to be successful since the tile has little or no wear and tear, as in stepping on it, etc. I have already discovered that buying the box to do a project gives low satisfaction, so I buy the products needed individually. So far as I can tell, the only problem left to solve is how to do the tile edges where they touch the carpet. If I figure that one out, I'm ready to go shopping and tackle it, lol. Thank you for your help.
Old 08-25-2007, 06:09 PM   #4
slickshift's Avatar
painting tile
You seem to have a firm grasp of the situation
I wish you luck, and offer any help if you have more questions
...I'm not sure about the tile edge though...against carpet?
I've not run into that
Would one of these help...
...keep the paint off the carpet?
Old 08-25-2007, 06:27 PM   #5
made in U.S.A.
Hamilton's Avatar
painting tile
Originally Posted by slickshift View Post
...or a bonding primer (XIM)...
Ah yes, XIM primer - excellent suggestion.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 08-25-2007, 06:34 PM   #6
painting tile
Yes, I think something like that would be the answer to the problem. Thank you again!
Old 08-26-2007, 01:28 PM   #7
poppameth
Guest
Posts: n/a
painting tile
In my experience BIN would be the best primer to use. It sticks pretty tight to glossy tiles without sanding them. So if you sand the glaze down and then apply it you should get a very good bond.
Old 08-26-2007, 02:43 PM   #8
painting tile
BIN sounds like the thing to use, even though the new surface won't be subject to water. Why take chances since if the bond fails, the whole project fails? Thank you for the information!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Painting ceramic tile mikemy6 Painting 8 06-22-2007 06:50 PM
ceramic tile painting c39c39 Painting 9 01-04-2007 03:24 AM
Painting a terra cotta clay tile roof? xoroniox Painting 2 12-13-2006 01:30 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
