Old 08-24-2006, 07:45 PM   #1
Defect Detective
LeveledHomeRepair's Avatar
Painting those nice straight lines in corners.
Hello all,
My question regards the best way to paint a nice even straight line. The spot where the wall meets the ceiling or one wall meets another and there will be a color transition. Should tape be used (the blue stuff) or is there a better way? If one uses tape, when should it be removed? Thanks again.
LeveledHomeRepair is offline   Reply With Quote
Old 08-24-2006, 08:54 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The best way for pros or DIYers continues to be a quality brush with quality paint and a steady hand
Tape can be used as a tool, but tends to make matters worse when used as a crutch
slickshift is offline   Reply With Quote
Old 08-25-2006, 10:24 AM   #3
I used tape in one situation like that, it is not perfect, but it is ok, and little inperfection can be fixed afterward with the 'Quality brush' and 'Steady Hand'... I find it extremely difficult to do it with a 'Steady Hand' alone, at least for DIYers I believed... or impatient people like me...
KUIPORNG is offline   Reply With Quote
Old 08-25-2006, 02:41 PM   #4
They're all fixer-uppers
J187's Avatar
http://www.taunton.com/finehomebuild...ges/hvt040.asp
J187 is offline   Reply With Quote
Old 08-25-2006, 03:23 PM   #5
By the time DIYers can do this, they probably have tried paint and damage approx... 20 straight lines...
Old 08-25-2006, 05:56 PM   #6
Defect Detective
J187,
Great video. Thanks everyone. I always thought the tape was a pain in the arse. I guess I just need some more from that cup of patience.
Old 09-03-2006, 06:55 PM   #7
The Flying Toolbox
handypilot's Avatar
Good quality brush, patients, and practice! The only time I use tape is when there is a color transition on the same wall (no corner), but this requires a different technique to prevent bleed-through.
Notice the emphasis on the brush! I recommend Purdy...I've had the same three brushes, for DIY projects, for 7 years. They're still like new.
handypilot is offline   Reply With Quote
Old 09-03-2006, 08:40 PM   #8
diy retard ;)
><(((jan(((D>'s Avatar
i've been using purdy brushes in my new home and would never go back to "cheap" brushes. not a single bristle stuck to the walls and after painting 5 rooms worth of trim three times over so far, they all continue to hold their perfect shape.
><(((jan(((D> is offline   Reply With Quote
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Laminate Lines Not Straight... sootybuttercup Flooring 7 09-01-2006 03:32 AM
