Painting A Textured Swirl Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 01:17 PM   #1
Painting a textured swirl ceiling
We have a pan ceiling in our dining room. It has never been painted. Could this be painted to bring out the beautiful swirl or should I leave it alone. If so what kind of paint should we use. I was thinking about a egg shell paint.
Cilla is offline   Reply With Quote
Old 06-06-2010, 10:25 AM   #2
I am no expert but from my experience with "popcorn" celing (swirl would be similar), Waterbased paint will dissolve the texture, to some extent, and will pull small pieces down.
This is further aggrivated by the "suction" associated with latex paint.
I have found that it can be primed with an oil based primer such as Kiltz. Then the finish latex paint can be applied with no problem.
This has worked many times for me and I hope it is helpful
Giles is offline   Reply With Quote
Old 06-08-2010, 11:30 AM   #3
Rewards Points: 152
I retextured my ceilings and used a white satin latex paint. If you want your ceiling to be noticeable, I would suggest it. I am really happy with the way they turned out.
Branden is offline   Reply With Quote
textured ceiling tips ronsyl Painting 2 05-26-2010 08:27 AM
Painting a California Knockdown ceiling Jim Caley Drywall & Plaster 2 02-27-2010 10:56 AM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 05:14 PM
Painting ceiling and wall (2 diff colors) when both are textured lavee383 Painting 4 07-21-2008 10:28 PM
Painting textured ceiling Unregistered Painting 5 06-17-2005 01:27 PM
