Painting Textured Mud Ceiling - Questions - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-29-2012, 06:41 PM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
Originally Posted by zakany View Post
I understand your advice to just use two coats of Muresco. Others suggested a different approach. If you think it is wise to use a $40 primer under a $25 paint, fine.
I mentioned buying a $20 primer because I can imagine it being thinner than a paint formulated to cover ceilings and causing as many problems as it solves. My follow-up indicates uncertainty.
Please realize that folks who come here asking do their best to synthasize differnt opinions into workable solutions. No slight is intended.
Am I going nuts? Did I not post multiple times that you do not need ANY primer for this job? Take it or leave it. Spend the $40 on primer, whatever
Old 09-29-2012, 06:43 PM   #17
chrisn's Avatar
Rewards Points: 224
Originally Posted by sdsester View Post
Because every once in awhile someone does listen and appreciate the advice. And they do not do something blazingly stupid like put nice, expensive paint over crappy, $2/gallon, poorly adhering primer---when one was not needed in the first place---and then wonder why the paint fails.
Hang in there. Hit some crabs with a hammer. You will feel better.
Now that sounds like a damn good plan
Old 10-09-2012, 07:25 PM   #18
Rewards Points: 150
Ceiling turned out fine. Here's what I did.
Cleaned it with a broom. That got about 90% of the cobwebs and assorted dirt off.
Filled the cracks with a paintable, white caulk.
Used an aluminum pole about 4-ft long with my roller to comfortably reach the ceiling, 3-in brush around the edges.
Two coats of Muresco Ceiling White, no primer, using a 1/2-in nap.
Excellent coverage with the first coat, making it hard to tell where I was with the second coat.
Ceiling was approx. 175 sq ft. One gallon was just enough for two coats.
zakany is offline   Reply With Quote
Old 10-09-2012, 08:03 PM   #19
Rubbin walls since'79
Brushjockey's Avatar
Used some of that today myself. My fav ceiling paint. I like to add a spash of water to loosen it up just a bit- and use a 1/2 super fab. Did a flat ceiling today- no texture at all. Came out great.
I love happy endings!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Painting Textured Walls DIYLoverKS Painting 3 09-23-2012 07:43 PM
two questions (ceiling fixture and clamps) Tonglebeak Electrical 1 07-05-2011 09:51 PM
drywalling over a warped textured ceiling JaniceB Building & Construction 4 05-29-2011 11:14 PM
painting a sand-textured ceiling? diy'er on LI Painting 1 03-30-2010 09:22 AM
Painting textured ceiling Unregistered Painting 5 06-17-2005 02:27 PM
