Painting Textured Dry Wall - Painting - DIY Chatroom Home Improvement Forum
Old 07-28-2013, 01:16 AM   #1
Rewards Points: 93
painting textured dry wall
My drywall has some blemishes on them and I want to touch up paint it.
I'm not repairing any walls just removing some blemishes.
My concern is my drywall is textured.
Should this be a concern?
dumbengineer is offline   Reply With Quote
Old 07-28-2013, 06:23 AM   #2
Jmayspaint's Avatar
Rewards Points: 534
Assuming you have some of the original paint to touch up with, the texture should actually work in your favor. Texture generally touches up easier than flat walls because the angular sheen is not as visible, and the touch ups don't show a 'flash' as bad.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (07-28-2013)
Old 07-28-2013, 09:28 AM   #3
Gymschu's Avatar
Rewards Points: 842
Originally Posted by jmayspaint View Post
assuming you have some of the original paint to touch up with, the texture should actually work in your favor. Texture generally touches up easier than flat walls because the angular sheen is not as visible, and the touch ups don't show a 'flash' as bad.
^^^^^^^this!
Old 07-28-2013, 10:05 AM   #4
Too Short? Cut it Again!
If the walls are painted in a wall that may have faded, or otherwise discolored or have a sheen that has degraded, I think you will find it will not take you that long to buy a gallon of paint and do the whole wall. I guess you can touch up and agree the texture may work in your favor.
Old 07-29-2013, 12:17 PM   #5
Rewards Points: 93
so touch painting or even painting a large area on a textured dry wall wont make the drywall flat/smooth, even with 2 coats?
i was concerned that paint would fill up those rough textures and make it smooth.
Old 07-29-2013, 12:22 PM   #6
Gymschu's Avatar
Rewards Points: 842
No, the paint won't fill in any of the textured areas unless you're using something thick like a textured paint which you don't need........just regular paint in the color you're trying to match.
Painting a wall that had a wall paper border removed Brandon_Lutz Painting 6 07-13-2011 08:34 AM
Painting ceiling and wall (2 diff colors) when both are textured lavee383 Painting 4 07-21-2008 10:28 PM
Painting 2-tone on a single wall question lmholmes11 Painting 3 07-18-2008 09:43 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
