Painting A Textured Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 11:01 AM   #1
painting a textured ceiling
I have read in several posts that you should roll in 1 direction. Does that mean if you are rolling from left to right that you remove the roller and go back and start at the left again? Why do you only roll in 1 direction?
thanks
ronsyl is offline   Reply With Quote
Old 05-30-2010, 09:17 AM   #2
Rewards Points: 530
If the texture has never been painted or sealed before, the new paint will rewet it and can cause it to peel off on your roller of you do a back and forth action on it.
The Following User Says Thank You to boman47k For This Useful Post:
ronsyl (05-30-2010)
Old 05-30-2010, 12:15 PM   #3
Drywall contractor
Rewards Points: 1,070
That's true of acoustic spray (popcorn). If it's a spray or roll on joint compound (stipple or knockdown) it's not a problem....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
ronsyl (05-30-2010)
Old 05-30-2010, 12:22 PM   #4
Rewards Points: 530
Thats true. I had popcorn in mind.
Old 05-30-2010, 12:25 PM   #5
Drywall contractor
I think thats' what the OP was talking about too. Just wanted to clarify in case it's something else.
Old 05-30-2010, 12:56 PM   #6
Rewards Points: 530
I guess I had popcorn on my mind because I never look forward to painting it the first time.
You were absolutely right in mentioning the different types of texture.
Old 05-30-2010, 01:13 PM   #7
Thanks I have joint compound
textured ceiling tips ronsyl Painting 2 05-26-2010 08:27 AM
Painting a California Knockdown ceiling Jim Caley Drywall & Plaster 2 02-27-2010 10:56 AM
painting over a textured ceiling tmtch540i Painting 1 04-04-2009 06:00 PM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 05:14 PM
Painting ceiling and wall (2 diff colors) when both are textured lavee383 Painting 4 07-21-2008 10:28 PM
