Old 03-06-2011, 03:03 PM   #1
Post
painting texture ceiling
What is the best way to repaint a textured ceiing. Not sure of the texture looks like a spray. In places where it is loose there is only unpainted sheetrock. This is a bedroom so no moisture problems.
gram6 is offline   Reply With Quote
Old 03-06-2011, 03:37 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
What type of texture?
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 03-06-2011, 09:38 PM   #3
The texture ceiling is from the late 70s. How can it be repainted without removing the original texture coat. This is a bedroom ceiling. Texture looks like a spray only on unpainted sheetrock under the original coat
Old 03-06-2011, 11:02 PM   #4
Finisher
Your best bet is to spray it - if it's loose and you try to roll it the texture will likely peel off as you roll.
A good bonding primer and a couple of finish coats by spray application should do it.
Rcon is offline   Reply With Quote
Old 03-07-2011, 10:17 AM   #5
Gymschu's Avatar
Rcon is right; however, if you don't have access to a sprayer, roll the places that are firmly adhered and use your brush where it seems to be loose. If you're using a flat paint you won't even notice any brush marks. If some of that texture comes off the ceiling, you're gonna have trouble matching it if you go to repair it.
Old 03-07-2011, 08:06 PM   #6
If you do roll it look for roller skins that are specially made for texture ceilings. The nap is a foam and has slits cut in it about 1/2" apart and doesn't require as much pressure as a regular skin would, so it doesn't "pull" on the existing texture as much. It should pretty much eliminate pulling any tight texture off. I have seen them at paint, hardware and box stores around here.
kboyz is offline   Reply With Quote
Matching drywall ceiling texture roger35768 Drywall & Plaster 10 10-15-2012 09:23 AM
HELP match my ceiling texture ksdriller Remodeling 1 11-09-2009 03:59 PM
painting over a textured ceiling tmtch540i Painting 1 04-04-2009 07:00 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 04:38 AM
popcorn ceiling painting phil334 Painting 2 07-12-2008 12:23 AM
