#1 |
Painting Technique Help
Okay, this is indeed good for a lolrof, but it is indeed a question I need help with.
I've seen professional painters pour the paint into a bucket, drop in a screen, and go. I'm painting a ceiling and thought I'd give this technique a try. My question is when putting the roller into the bucket of paint, how far do you go? Dunk the roller all the way? Halfway up the roller (i.e., to the point of the hub? Just touch the surface of the paint? OK, now that you've picked yourself off the floor and wiped the tears of laughter from your face, what's the answer?!? Thanks, Richard |
#2 |
Richard, I would never dip the roller deeper than the thickness of the nap. If you get paint all over the roller handle ends, you'll have a drippy mess, especially on the metal end.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Use the screen to turn the nap dipping it all the way around.Like Jsheridan said,not deep enough to cover the ends of the roller frame.
Charlie Daniels painting and repair |
| The Following User Says Thank You to cdaniels For This Useful Post: | ltd (01-31-2013) |
#4 |
JSheridan and CDaniels,
Thanks for the feedback! Richard |
#5 |
Richard, your question was so basic that I think we should have expounded a little more on rolling technique. As cdaniels said, dip the roller into the bucket to pick up the paint as stated, pull it up and lightly roll it over the screen two or three times, dip again, repeat. The screen is what is going to distribute the paint evenly across the roller nap. Do not apply pressure against the screen/grid.
When the roller is new I would spend a few minutes doing the dip/screen routine. The roller needs to fill, meaning the paint needs to seep down to the core of the roller, to fill the "reservoir". It needs about 10 minutes or so of dip/screen and wall rolling to fill. After the few minutes you can start rolling. When a roller is full, you should get about 1 and 1/2 roller widths out of each roller dip from the bucket. Go slow at first, doing a much smaller area, and redip when the roller starts to feel empty. After about ten minutes of gradually increasing the coverage area the roller should fill, and it should feel like it covers the 1 and 1/2 without difficulty. Put the roller to the wall and roll straight up and down floor to ceiling, then move forward half the roller width, this is laying the paint on. Then gently go up and down, back and forth to fill it in. Finish by starting where you end and back to where you started to lay off, gently and lightly. On your next dip start right where you left off and repeat the above steps. Always:
Never:
I may have missed some things that others might add in, but that should give you some things to think about and get you started toward professional results.
| The Following User Says Thank You to jsheridan For This Useful Post: | Grants Painting (02-07-2013) |
| Display Modes | |
| Looking for painting technique suggestion | mjkelly93 | Painting | 10 | 04-19-2012 04:35 AM |
| faux marble painting technique | vhon | Painting | 7 | 07-23-2011 12:10 AM |
| Proper painting technique.... | simiesue | Painting | 13 | 06-20-2011 04:45 PM |
| Small project painting technique | daviddoria | Painting | 3 | 01-13-2010 05:17 AM |
| Painting Technique to look like "Grass"? | GoldChain | Painting | 2 | 05-28-2007 02:09 PM |
